Computational Fluid Dynamics (CFD) workbench using OpenFOAM
Moderator: oliveroxtoby
oliveroxtoby
Re: Computational Fluid Dynamics (CFD) workbench using OpenFOAM
Post by oliveroxtoby »
thschrader wrote: Mon Mar 28, 2022 3:31 pm Just updated the
cfdof-wb, hisa-solver, cfmesh
Hisa:
when running this file
capsule_hisa.FCStd
this happens:
--> FOAM FATAL IO ERROR:
Cannot find patchField entry for inlet
file: C:/GA-NT/Anwendungen/TS_513538/CFD/case/0/epsilon/boundaryField from line 26 to line 18.
From function void Foam::GeometricField<Type, PatchField, GeoMesh>::Boundary::readField(const Foam::DimensionedField<TypeR, GeoMesh>&, const Foam::dictionary&) [with Type = double; PatchField = Foam::fvPatchField; GeoMesh = Foam::volMesh]
in file X:/OpenFOAM-8/src/OpenFOAM/fields/GeometricFields/GeometricField/GeometricBoundaryField.C at line 184.
FOAM exiting
I wanted to run the new k-epsilon turbulence model with this file:
naca2412_k_epsilon.FCStd
this happens:
File "C:\Users\thomas.schrader\AppData\Roaming\FreeCAD\Mod\CfdOF\.\_TaskPanelCfdPhysicsSelection.py", line 180, in accept
FreeCADGui.doCommand("obj.TurbulenceModel = '{}'".format(
<class 'ValueError'>: 'kEpsilon' is not part of the enumeration in naca2412_k_epsilon#PhysicsModel.TurbulenceModel
Thanks for the testing! Both issues hopefully resolved.
thschrader
Post by thschrader »
oliveroxtoby wrote: Mon Mar 28, 2022 9:52 pm ...
Tested the naca-profile from above, works.
But you must edit the epsilon file. The epsilon value is too low
in the written file, simplefoam crashes. However...
But interesting result. k-omega model converges, k-epsilon not :o
oliveroxtoby
thschrader wrote: Tue Mar 29, 2022 4:01 pm
Did you not mean to enter 2.5 m^2/s^3 = 2.5e6 mm^2/s^3? 2.5e3 mm^2/s^3 as shown is equal to 0.0025 m^2/s^3, as written. Or am I missing something?
thschrader
oliveroxtoby wrote: Tue Mar 29, 2022 7:09 pm ...
:oops:
Yes, you are right, exponent must be 6, because of m^2. Tricky unit gambling...
I guess there will be some more users in the future posting a question about this :)
Maybe switching to m^2 input in epsilon? Like in k.
oliveroxtoby
thschrader wrote: Wed Mar 30, 2022 5:41 am
:oops:
Yes, I plan to put in a pull request to the FreeCAD base code to address this. There are a few places in CfdOF where similar illogical units are displayed. It would be good to fix them all at the same time, so if you encounter any others please let me know here. So far I have:
mm^2/s^3 -> m^2/s^3 (epsilon)
mm^3/s -> m^3/s (or l/s - it can be adaptive) (volumetric flow rate)
1/mm -> 1/m (Darcy-Forchheimer inertial coeff)
1/mm^2 -> 1/m^2 (Darcy-Forchheimer viscous coeff)
thschrader
oliveroxtoby wrote: Wed Mar 30, 2022 7:20 am ... so if you encounter any others please let me know here. So far I have:
some more...
oliveroxtoby
thschrader wrote: Thu Mar 31, 2022 2:56 pm some more...
Thanks. The first three will actually change as you request if you set your unit system to m/kg/s. We unfortunately can't change them under mm/kg/s as they are used globally and defined this way already. The places where you requested mm should be fine as they are adaptive and should show up as the appropriate unit whether under m/kg/s or mm/kg/s.
thschrader
8-)
Thanks for this add.
trijonb
Post by trijonb »
thschrader wrote: Sun Apr 03, 2022 12:22 pm 8-)
:thumbsup
Crossleyuk
Post by Crossleyuk »
Hello All,
Moved back to my old Forum page to keep my new VXA page tidy. I have a request for a little help on the next step of my CFD equiries on a new CFD model. This is the failure I received and the report text.
Hope you can help, realy keen to make progress
Thank you again
Michael
Body_Cyl_Axial_Complete_Rev_P2_Error_05-22-22.docx
(29 KiB) Downloaded 45 times
