Computational Fluid Dynamics (CFD) workbench using OpenFOAM
Moderator: oliveroxtoby
thschrader
Re: Computational Fluid Dynamics (CFD) workbench using OpenFOAM
Post by thschrader »
Crossleyuk wrote: Thu Sep 30, 2021 9:41 am ...
Crossley_Simple_Cylinder_019.FCStd
Hi Michael,
I ran your cylinder case and I get the same errors like you.
The example was done with FC0.19, right?
Maybe this confuses FC0.20.
Try to rebuilt the complete case with the newest FC0.20 dev-snapshot.
Dont use inlet with pressure definition. Use velocity for testing and
potential flow for initializing v/p-fields.
Regards Thomas
Syres
Post by Syres »
thschrader wrote: Thu Sep 30, 2021 4:02 pm The example was done with FC0.19, right?
I was caught out by the Topo changes to Cylinders using the Curves workbench see https://forum.freecadweb.org/viewtopic. ... 98#p536895
Crossleyuk
Post by Crossleyuk »
Hi Michael,
Regards Thomas
Thank you Thomas,
I was thinking allong these lines myself, yes, FreeCAD 0.19. This was my very first case but having problems with all my FC0.18 cases as well. Not come across FC0.20 dev-snapshot yet and certainly will take a look tomorrow.
Nice to have a name Thomas, thanks again.
Michael
nixxx
Post by nixxx »
Hi guys,
I understand the CFDOF user interface does not provide access to all of the functionality of OpenFOAM, right? But, can this be accessed via the OpenFOAM_Start shortcut that is created during the installation? E.g, is this a full OpenFOAM installation or does it have some limitations?
Crossleyuk
Hi Michael,
Regards Thomas
Hi Thomas,
Thanks but I don't see FC0.20 available for Windows and don't have the skills available to do any more.
I have a lot of FC0.18 cases that worked fine before my PC and FreeCAD 0.19 changes. Should I expect them to run in FC019? I cannot get them to work at all. Is this suggesting that a FC018 case is not applicable in FC19?
My next step is to go back to FC18 and check things out again
Michael
oliveroxtoby
Post by oliveroxtoby »
nixxx wrote: Fri Oct 01, 2021 8:45 am Hi guys,
Yes, CfdOF interfaces with an external installation of OpenFOAM from one of its various suppliers. The installation is just a convenience and it is indeed the full, unaltered version.
oliveroxtoby
Crossleyuk wrote: Thu Sep 30, 2021 9:41 am OS: Windows 10 Version 2009
Version: 0.19.24291 (Git)
Branch: releases/FreeCAD-0-19
Python version: 3.8.6+
Qt version: 5.15.2
Coin version: 4.0.1
OCC version: 7.5.0
Thanks for understanding Oliver,
Crossley_Simple_Cylinder_019.FCStdCrossley_Output_Report_30-09-21.pdfOpenFOAM_Directory-03.PNG
Crossley_Python_Console_30-09-21.pdf
Please let me know if I can do any more.
Michael
Hi Michael
When I open the file in 0.19 there is an error shown on the "Pad" object (red exclamation mark): "Linked shape object is empty". I'm not sure what the cause is exactly but you might need to re-generate the geometry (and afterwards, make sure your boundary conditions are pointing to the right faces). Presumably something changed in FreeCAD between version 0.18 and 0.19 to break your saved file.
Crossleyuk
Hi Oliver,
I opened that case and saw the Pad error so redrew the case below and dis not get teh Pad exclamation mark.
I rand the new case and I got the following response:
Crossley_Simple_Cylinder_019_#2.FCStd
(105.09 KiB) Downloaded 91 times
oliveroxtoby
Crossleyuk wrote: Sun Oct 03, 2021 11:09 am Hi Oliver,
Hi Michael
Looks like the same error you asked about a few weeks back. Please see my response here: https://forum.freecadweb.org/viewtopic. ... 00#p532769
Crossleyuk
Sorry Oliver, you were correctbith times :roll:
But the calclations crearly start providing me with the Ux, Uy and Uz chart dialogue, but I then get exit with error and:
C:\Users\Michael Crossley\AppData\Roaming\FreeCAD\Mod\CfdOF\CfdResidualPlot.py:68: UserWarning: Data has no positive values, and therefore cannot be log-scaled.
ax.set_yscale('log')
Seriously wish I could follow all this.
Michael
