Computational Fluid Dynamics (CFD) workbench using OpenFOAM
Moderator: oliveroxtoby
oliveroxtoby
Re: Computational Fluid Dynamics (CFD) workbench using OpenFOAM
Post by oliveroxtoby »
Crossleyuk wrote: Sun May 22, 2022 11:41 am Hello All,
Moved back to my old Forum page to keep my new VXA page tidy. I have a request for a little help on the next step of my CFD equiries on a new CFD model. This is the failure I received and the report text.
Hope you can help, realy keen to make progress
Looks like the solution diverges in a few iterations. Very difficult to tell anything from the output. If you can share your case that may help. Alternatively, setting the write interval to output every iteration may give you some clue as to where things are going haywire.
Crossleyuk
Post by Crossleyuk »
Thanks yet again Oliver. This is another first for me but thak goodness for your support. I'll follow your suggestion and take a closer look. Cheers :geek:
Crossleyuk
Sorry Oliver, I can't find how to allow me to sett the "write interval to output every iteration". I expected to see it in the cfdof parameters. Where can I change that?
Crossleyuk
Here is the case that I'm working on. It's a little complicated because I've included the external an internal components to the actual CFD flow regions. Hope it helps.
Body_Cyl_Axial_Complete_Rev_P2.FCStd
(431.45 KiB) Downloaded 41 times
Michael
trijonb
Post by trijonb »
Hi Michael,
Check your mesh, this is what it looks like currently (from your provided case).
Jon
thschrader
Post by thschrader »
Crossleyuk wrote: Mon May 23, 2022 8:47 am Sorry Oliver, I can't find how to allow me to sett the "write interval to output every iteration". I expected to see it in the cfdof parameters. Where can I change that?
You can adjust the parameter in the solver data-tab.
alternative: edit control-dict after case writing.
Crossleyuk
Thanks, but very strange, this is the mesh from my case here. Exactly what I expected and have had in the past.
So still confused ;) but as suggested, I'll now check the write interval.
Michael
thschrader
This is what I get.
CheckMesh gives back a failed warning, see report view.
I dont know if this is critical for your simulation.
Have a closer look at the cylinders. It looks like that
there are some mesh inconsistencies...
I tried cfmesh ==> openFoam crash
snappyhexmesh: 30 min runtime, I gave up...
GMSH seems the best way, maybe there are some glitches in your model?
Crossleyuk
WOW, thank you. Yet again I'm gratefull for your support and to be honest lessons. I now know what to be looking for now and in the future. I had the same problem with cfmesh so used gmesh. Great help and a clear direction for tomorrow, I'll remake that region of the model and mesh and check the details you've picked up. Fanatic help, thank you very much!
Michael
Crossleyuk
HaHa,
I got exactly the same response as you for cfMesh abd gmsh gave me the one that you saw the concerns for. So I was away for a away for a while and thought I'd try SnappyHex. And this is what it gave me after 55 minutes 8-) .
So I'm going to rebuild that area of my case model and try meshing again. Thanks again, I learn so much every time we have these exchanges.
Michael
