Computational Fluid Dynamics (CFD) workbench using OpenFOAM
Moderator: oliveroxtoby
Crossleyuk
Re: Computational Fluid Dynamics (CFD) workbench using OpenFOAM
Post by Crossleyuk »
thschrader wrote: Tue Sep 21, 2021 10:34 am 1. Uninstall bluecfd
2. Goto "Apps and Features", check for remaining mpi. If so, uninstall via "Apps and Features"
3. Reboot system
4. Install bluecfd, newest version https://bluecfd.github.io/Core/Downloads/
Works for me.
Hi again all,
I've had no success so decided to do a complete reinstall of FreeCAD and CfdOF with further investigations after the same mpiexec failure. I finally even downloaded the latest, version 10, of Microsoft MPI with no change at all.
mpiexec is available at C:\Program Files\Microsoft MPI\Bin
Please help, desperate to get back into my research after Covid-19.
Best regards
Michael
Crossleyuk
I can't get a completed dependancy check success. After going hrough the rebuild I still get:
Checking dependencies...
cfMesh (CfdOF version) not found
I've updated CfdOF several times from Addon Manager and receive this red error regularly in the Report view:
15:02:35 openfoam: windows support (mingw64) is runtime only
15:02:58 4.8.3
Syres
Post by Syres »
Crossleyuk wrote: Tue Sep 28, 2021 2:09 pm Checking dependencies...
Are you sure you are running FreeCAD as an Administrator?
Crossleyuk
Syres wrote: Tue Sep 28, 2021 3:49 pm
Thanks Syres, I'll check that out.
Crossleyuk
oliveroxtoby
Post by oliveroxtoby »
oliveroxtoby wrote: Mon Sep 27, 2021 8:17 pm
Crossleyuk wrote: Thu Sep 23, 2021 3:29 pm Sorry, finally understood your suggestions and now know how to update the workbench, so that is done for Plot and CfdOF.
Unfortunately, no change niether my own models or your suggested naca2412 finish with Simulation exited with error
During CfdOF run I receive a red error ? statement "openfoam: windows support (mingw64) is runtime only"
Regards,
Michael
Hi Michael
You have been following thschrader's advice to re-install blueCFD; however, the error message above suggests you are still using the OpenCFD installation - this is a different Windows packaging of OpenFOAM than blueCFD. So all your reinstallations of blueCFD won't have any effect unless you tell CfdOF to use it. Do this by changing the OpenFOAM installation directory in Preferences to the location where you installed blueCFD, or alternatively, un-install the OpenFOAM installation and leave only the blueCFD one. CfdOF should then automatically use blueCFD if I remember correctly.
You may have missed my reply above. The "windows support us runtime only" error message you mention is not a concern, just a warning printed by the OpenFOAM environment.
It is important to note that there are two different packages of OpenFOAM supported (the ESI/OpenCFD OpenFOAM package, and blueCFD), and you appear to have both installed which is causing confusion. They each come with a specific version of MSMPI and are potentially incompatible with other versions.
I suggest you uninstall both of them, as well as all versions of MSMPI, and then re-do the installation of your preferred package (probably blueCFD, as per the instructions above), making sure to run the installer as administrator and allow it to install MSMPI.
Good luck!
Crossleyuk
Thanks Oliver,
Sure I saw your previous post and thought I'd carried this out as you suggested. So I'm starting again and want to be clear before reinstalling.
I've uninstalled OpenFOAM, blueCFD and MSMPI but looking at my Program Files folder there are still folders and files in the blueCFD folder. Is this what you would expect or should I delete them manually. I'm trying to be clear because all this is black magic to me :lol:
Thanks for putting up with my naivety again, I'm merely a user :roll:
Michael
Crossleyuk
Couldn't sleep so decidede to delete the blueCFD-Core-2020 folder from Program Files and follow your instructions. I then ran FreeCAD as administrator again and it resulted in ./Allrun: line 9: mpiexec: command not found
Hang on. Should I have an entry in OpenFOAM install directory? I did try C:/Program Files/blueCFD-Core-2020/OpenFOAM-8
And recieved C:\Users\Michael Crossley\AppData\Roaming\FreeCAD\Mod\CfdOF\CfdResidualPlot.py:68: UserWarning: Data has no positive values, and therefore cannot be log-scaled.
ax.set_yscale('log')
Sorry, completely lost
Michael
oliveroxtoby
Crossleyuk wrote: Thu Sep 30, 2021 3:27 am Couldn't sleep so decidede to delete the blueCFD-Core-2020 folder from Program Files and follow your instructions. I then ran FreeCAD as administrator again and it resulted in ./Allrun: line 9: mpiexec: command not found
This is a good idea to avoid any ambiguity. If you leave this blank, CfdOF tries to detect it automatically, and athough you have uninstalled everything else, it souns like the ESI/OpenCFD version was still being picked up. If you specify it, you know exactly which OpenFOAM package is being used.
Michael
Now you are getting a different error, which seems like a good thing. This needs to be sytematically investiated and unfortunately the final error message is generally of little use in diagnosing a problem. Please include the full output from the report view and upload your failing case in order to allow others to reproduce the problem and help you. To avoid further confusion, I suggest you leave your configuration as it is for now (avoid any more uninstalling/reinstalling) so that this latest problem can be investigated in a systematic way.
Crossleyuk
Version: 0.19.24291 (Git)
Branch: releases/FreeCAD-0-19
Python version: 3.8.6+
Qt version: 5.15.2
Coin version: 4.0.1
OCC version: 7.5.0
Thanks for understanding Oliver,
Crossley_Simple_Cylinder_019.FCStd
(153.98 KiB) Downloaded 84 times
Crossley_Output_Report_30-09-21.pdf
(68.84 KiB) Downloaded 79 times
Crossley_Python_Console_30-09-21.pdf
(70.35 KiB) Downloaded 82 times
Please let me know if I can do any more.
Michael
