IFC Master File, workaround for ifc not opening directly. example of the construction of lines in a bim process
- thomas-neemann
In this video you can see what an ifc master file is
https://www.youtube.com/watch?v=uh6q32-jl4U
edit
https://www.youtube.com/watch?v=D2K0IEr-5mk
edit
Last edited by thomas-neemann on Sat Jun 11, 2022 5:04 am, edited 1 time in total.
Re: IFC Master File
Interesting.
So how would you translate that to FreeCad? How would I start if I have different stakeholders to a project each with their own model and have to connect/coordinate them using FC?
Would be nice to have conceptual write up of the possible approaches to this problem.
- thomas-neemann
Re: IFC Master File
I could create an example workflow in the form of video and link it here
- thomas-neemann
Re: IFC Master File
- thomas-neemann
Re: IFC Master File
part 2. the dimensions of the structural engineer are built into the model by the architect.
https://www.youtube.com/watch?v=LmRSCHieZUg
- ebrahim raeyat
Re: IFC Master File
This application is very fantastic, the ideas is very good. is it open source?thomas-neemann wrote: ↑Fri Sep 10, 2021 7:52 pm In this video you can see what an ifc master file is
Thanks a lot.
- thomas-neemann
Re: IFC Master File
no it is not open source. but it's all about the workflow. everything is also possible with freecad
- ebrahim raeyat
Re: IFC Master File
Thanks, Can we do the same things in FreeCAD?! Can you show how we can? I saw your videos for FreeCAD, but it is difficult to do it in FreeCAD, isn't it?thomas-neemann wrote: ↑Mon Sep 13, 2021 7:56 amno it is not open source. but it's all about the workflow. everything is also possible with freecad
- thomas-neemann
Re: IFC Master File
as long as you only work with geometry, everything is very easy. it gets tedious when attributes are to be used.
- thomas-neemann
Re: IFC Master File
https://www.youtube.com/watch?v=0ALqIoJFXA0
