videos from thomas-neemann, arch, BIM, IFC, metal ,steel, wood, mechanical engineering etc
A place to share learning material: written tutorials, videos, etc.
thomas-neemann
Re: videos from thomas-neemann, arch, BIM, IFC, metal ,steel, wood, mechanical engineering etc
Post by thomas-neemann »
exercise 3d sketch, tangential transitions
https://www.youtube.com/watch?v=IOZh_SHzsCA
phpBB [video]
thomas-neemann
"Automatically" generate ifc file from point cloud
https://forum.freecadweb.org/viewtopic.php?f=39&t=70522
thomas-neemann
Sheet metal processing and DXF CNC export
https://www.youtube.com/watch?v=a1Y0QowEl4g
phpBB [video]
thomas-neemann
fast stable construction mechanical engineering
https://www.youtube.com/watch?v=p9Ab8QwLthU
phpBB [video]
Isabel
Post by Isabel »
What exactly do you mean by "stable"? To me this looks quite misleading, because I expect from a really stable model, that you can e.g. change the outer radii and and the rest will follow. I don't see this in your model, but I may be mistaken. Perhaps you can upload the model so that we can play with it.
thomas-neemann
Isabel wrote: Fri Aug 26, 2022 11:10 pm What exactly do you mean by "stable"? ...
no flipping or tnp during build or remodel. Here is an example and the files
https://www.youtube.com/watch?v=oGcnWl7H53c
phpBB [video]
2029-fin.FCStd
(52.28 KiB) Downloaded 100 times
727.FCStd
(156.03 KiB) Downloaded 96 times
Isabel
Post by Isabel »
thomas-neemann wrote: Sat Aug 27, 2022 6:03 am no flipping or tnp during build or remodel. Here is an example and the files
Thanks for the files!
There are never ever any TNP problems during building. And what you show in the video is not really editing the model, but continuing to model new stuff.
thomas-neemann
Isabel wrote: Sat Aug 27, 2022 8:23 am .... what you show in the video is not really editing the model, but continuing to model new stuff.
words are difficult, so i prefer to be silent in the videos and write as little as possible. I like videos the best
I would second Isabel. Instead of asking in an abstract way, lets get more concrete: A case where a badly built model could break is this:
Change in "Wire" the big radius from 40mm to 45 and both small radii from 22 to 25.
How would you tackle this?
thomas-neemann
chrisb wrote: Sat Aug 27, 2022 8:28 am ....
it depends on the case. your case is better to change with the sktecher (and work with the sketcher from the start). in my case the change with part is probably faster
