I'm trying to create an drawing view of an simple assembly. Some lines are missing in the areas where the parts meet. Would there be a setting to optimize the view so that that the lines would show up? The flange does have holes where the parts meet.
Syres wrote: ↑Wed Sep 28, 2022 10:29 am
OK, could you please upload the file so it can be analysed, it could be something in your config files but it's best to eliminate the file first.
Plenty of errors loading on my box, the main issue which you didn't mention was you were using a A2Plus component with Fasteners placed as completely seperate items. I'm a big fan of A2Plus to do assembly as long as I don't need to make Tech drawings of them but if I need a tech drawing then I leave all objects as standard and use the transformation data to place them correctly. I've managed to come up with a solution for this instance and it's to create a Fusion of the 5 objects then create the View from that.
