Thanks for your answers, very helpful.
Complex Sections
- wandererfan
Re: Complex Sections
I'm sure they are not commonly used, but Domad seems to have a very extensive knowledge about what the standards actually allow. I believe he made these examples just to show what is possible when still adhering to the conventions. I agree that these corner cases are not that important in practice, and not much effort should be directed to achieve those oddball situations. I still think it's nice to know what can be done in those rare cases, so personally I give much respect to Domad's insight about these technical matters.
I finished testing the latest version of WandererFan's PR (Git 30420 +10), and it's works mostly very very good! There are still some bugs, which I'll list here. I recreated Domad's examples with this new ComplexSection tool, and it was remarkably easy: Just create sketches in 3D-view for the desired section profiles; select a View and a section profile Sketch, and press the icon "turquoise Pac-man eating a staple" in TD. Domad's examples A - A, B - B, C - C, and D - D worked perfectly, while E - E failed because one of the section segments wasn't actually a cut:
But anyways, the four first examples easily and automatically re-created the section images in Domad's examples perfectly, without the painstaking manual operations. IMHO, this is already a very well-done new feature, and a must-have addition to TechDraw! I found some minor bugs, which hopefully are easy to fix:
23:47:54 DVS: Section cut has failed in ComplexSection005
23:47:54 DVS::makeSectionCut - prism & input don't intersect - Section E - E
23:47:54 DVS::prepareShape - failed to build shape ComplexSection005 - Bnd_Box is void **
- The "can't make a cut"-problem in one segment causes the whole section to fail, as mentioned above
- FreeCAD crashes, if you make a piecewise section in direction [0,1,0] and later change that into [0,-1,0] in the Data tab (or into any other value). Directly making section in direction [0,-1,0] is fine, though, but later changing the direction value causes crash
- In parallel section if you similarly change the section direction, and update the whole TD, the edges are re-drawn correctly in new position, but the hatching is a weird mix of old, new and missing hatching. No crash, though!
OS: Debian GNU/Linux bookworm/sid (KDE/plasma)
Version: 0.21.30420 +10 (Git)
Branch: (HEAD detached at WandererFan/ComplexSection)
Hash: c7ac6d7cc1ceed415aad1a4b3a7ab88bdce4b909
Python 3.10.7, Qt 5.15.4, Coin 4.0.0, Vtk 7.1.1, OCC 7.6.3
* Assembly4
* Render
* fasteners
* FCGear
* Manipulator
* Curves
* sheetmetal
- 20220929 TD ComplexSection test v4.FCStd
- (110.82 KiB) Downloaded 36 times
Greetings to the Community!
Another example of an aligned and concurrent section, here a way of how you could implement the section line functionality with changes of direction (or placed on different floors) https://help.spaceclaim.com/2015.0.0/en ... ctions.htm
- Example_of_aligned-concurrent_section_domad.FCStd
- (81.14 KiB) Downloaded 32 times
- Example_of_aligned-concurrent_section.png (180.85 KiB) Viewed 1565 times
Hi @aapo, hello to the community!
Very well your experimentation!
Great development work by @wandererfan, as I see very soon we will have the "Create Complex Section" function available.
... section E-E of the previous intervention can also be represented as a half-section
- Half-section.png (176.26 KiB) Viewed 1550 times
Thanks for the interesting example! I'm not sure that this case will be possible in FreeCAD, unless extra code will be added to make it possible to ignore selected segments in the piecewise ComplexSection projection. Then, it would be possible to do this in the piecewise ComplexSection mode, by ignoring the two perpendicular segments. I think this could be as easily added later on, so maybe it could be postponed to after WandererFan has finished coding the main feature.domad wrote: ↑Fri Sep 30, 2022 2:49 pm Greetings to the Community!
EDIT: Added ComplexSection version of Domad's new example, it doesn't seem to work as well as simpler examples, unfortunately.
* Assembly4
* Render
* fasteners
* FCGear
* Manipulator
* Curves
* sheetmetal
- 20220929 TD ComplexSection test v5.FCStd
- (34.79 KiB) Downloaded 34 times
- wandererfan
Awesome test file. It exposed lots of unstated assumptions in the code. Thank you.
- csManySegmentPiecewise.png (25.66 KiB) Viewed 1470 times
You're most welcome, and thanks for developing this! We should thank domad for the example, though, as it's his design on the previous page. I just converted it to work with your new ComplexSection branch, in order to see how the new code handled domad's more esoteric example. I can confirm that it now works correctly with the newest code, and everything else I just tested with the newest version also worked nicely, except that the hatchings in example 4 (re-attached) have some weird problems with circular disks at the fillet sections (see example pic).wandererfan wrote: ↑Tue Oct 04, 2022 12:36 pm Awesome test file. It exposed lots of unstated assumptions in the code. Thank you.
Apart from that, are we now maybe close to get your excellent code for the main branch, soon? It's a really important feature, and to me it seems that everything is starting to be in place now.
Version: 0.21.30429 +102 (Git)
Hash: 29525fdbef2cfc2ad1846a33741eb5c32def3f95
Python 3.10.7, Qt 5.15.6, Coin 4.0.0, Vtk 7.1.1, OCC 7.6.3
* Assembly4
* Render
* fasteners
* FCGear
* Manipulator
* Curves
* sheetmetal
- (110.82 KiB) Downloaded 32 times
- wandererfan
