Is there already a way how to change the way the handles look? Quite often there is a need to place a lead line arrow precisely:
1) to make the handels some what transparent
OR
2) just outline the handles:
When editing the points the "handles" are presented by these squares which in their current form block the view:
To be able to see where you are placing the line end an improvement would be:Techdraw - Lead Line - Edit Points
Re: Techdraw - Lead Line - Edit Points
Where would one need to look in the code to find the appearance definition of the "control squares" ?
- wandererfan
Gui/QGEPath.cpp (QGraphics Editable Path) in showMarkers. Adding "v->setFillStyle(Qt::NoBrush);" should do it.
To do the whole job, we should also add a preference for marker shape and fill.
Thanks!
btw. The Clip group clips also the Lead Lines:
As a Lead Line belongs to a view I guess this is a feature. The workaround is to increase the Clip area.
