[ Fixed ] New TechDraw_ActiveView does not work?
Roy_043
Post by Roy_043 »
When I try the new TechDraw_ActiveView command I get the error listed below. The created view is empty (just the dashed outline and the label).
17:03:41  G3d::quickView - no viewer for ActiveView - returning
17:03:41  <class 'SyntaxError'>: ("(unicode error) 'unicodeescape' codec can't decode bytes in position 2-3: truncated \\UXXXXXXXX escape", ('<string>', 1, 45, None))
17:03:41  Unhandled Base::Exception caught in GUIApplication::notify.
The error message is: ("(unicode error) 'unicodeescape' codec can't decode bytes in position 2-3: truncated \\UXXXXXXXX escape", ('<string>', 1, 45, None))
Version: 0.21.30345 (Git)
Hash: f42a47aa0fd8c4f34ef63c185d9f29b9b6e84737
Python 3.8.13, Qt 5.15.4, Coin 4.0.0, Vtk 9.1.0, OCC 7.6.3
wandererfan
Re: [ Bug ] New TechDraw_ActiveView does not work?
Post by wandererfan »
Roy_043 wrote: Sun Sep 11, 2022 3:06 pm When I try the new TechDraw_ActiveView command I get the error listed below. The created view is empty (just the dashed outline and the label).
Are you on the 3d view or the TD page view when you push the button? If I'm on the TD page, I get a message about no active view, but nothing about "unicodeescape codec". I'll try on windows next time I'm near that machine.
I think I'll have to add something to search the 3d views if the "active view" isn't a 3d window.
Roy_043
Post by Roy_043 »
wandererfan wrote: Sun Sep 11, 2022 4:12 pm Are you on the 3d view or the TD page view when you push the button?
The error occurs in either case.
wandererfan
Was not handling "\" in file names properly. Should be fixed by git commit 92294c448e.
Roy_043
Re: [ Fixed ] New TechDraw_ActiveView does not work?
Post by Roy_043 »
Thanks for the fix.
