- Expression Not Recalculated on Change of Position issue #6943
- Allow Adjustment of Stacking Order of Views issue #6012
- add PrintAll Command
- make text correct height (forum thread)
- remove white matting around detail view (forum thread)
New Functions and Fixes
- wandererfan
Changes for the following are now in master branch:
Reason: put forum threads in to hyperlinks
Re: New Functions and Fixes
Yeah! Many many thanks!
Greetings
user1234
I'm eager to try all new funcionalities.
Thank you so much @wandererfan
Thanks for your work. For me the fixes come just at the right time. The Tech Draw workbench is my most used workbench at the moment. Now it is very much faster to work with it on my machine. Loading time for files is enormous quicker, the complete workflow now is smooth without loosing many seconds for calculating interruptions. I got curious about improvements because of a toot in mastodon, so I installed the 0.21 daily build. I am sure to finish my project with the 0.21 now, cause I don´t want to miss the improvements.
