If you create a template and use the parameter dominant-baseline for setting the text position point in to the middle height for example, the TechDraw viewer does not render it properly. It is trivial if you use it as a SVG parameter or as a Style parameter.
dominant-baseline="middle"
TechDraw does not work with SVG parameter dominant-baseline
- tobiasfalk
Re: TechDraw does not work with SVG parameter dominant-baseline
@tobiasfalk welcome to the FreeCAD forum. Note: please wait to open a ticket.
CC @wandererfan, OP opened issue #7076
- wandererfan
Svg functionality is provided by Qt. Qt supports only the static features of SVG 1.2 Tiny. I don't have a copy of that standard handy, but I would guess that dominant-baseline is not included.tobiasfalk wrote: ↑Wed Jun 22, 2022 3:51 pm If you create a template and use the parameter dominant-baseline for setting the text position point in to the middle height for example, the TechDraw viewer does not render it properly. It is trivial if you use it as a SVG parameter or as a Style parameter.
- tobiasfalk
Thx. for the answer
@wandererfan are there plans for Qt to expand it's support. How would we say implement auxiliary SVG support? (that would cover the gap that Qt doesn't address)
- wandererfan
The last time I investigated, Qt considered its Svg functionality to be complete and no further enhancements were envisioned. Any further Svg development will be in QtWebEngine which is not a direct replacement in any way.
Replacing QGraphicsSvgItem, QSvgGenerator, QSvgRenderer, etc is a big job.
