hi
i had find, that after updating edited assembly in TECHDRAW it didn't properly show the state of the project.
does it bug, or not?
Just i didn't find this branch, so i already had described it here in 2 topics
https://forum.freecadweb.org/viewtopic.php?f=8&t=69431
https://forum.freecadweb.org/viewtopic.php?f=8&t=69424
- wandererfan
Re: updating edited assembly in TECHDRAW
You don't need 3 topics in multiple sections for 1 question.antondroid wrote: ↑Tue Jun 14, 2022 4:22 pm Just i didn't find this branch, so i already had described it here in 2 topics
If you want a decent answer, you'll have to provide files (the one with the TechDraw page, the assembly and the components) so we can actually see what is going on.
I suspect you need to recompute the View to pick up the changed assembly.
i had pressed the 'redraw page' button, as i had mentioned in that topics,you need to recompute
but i didn't find 'recompute', would u like to prompt in which folder it placed?
just i can't to remove those topics, and at first i didn't saw this branch, so i didn't doubled that topics here.
and the original files had attached to that topics, of coarse.
- wandererfan
The file in the other post doesn't have a TechDraw Page, so we are only guessing what you are doing.antondroid wrote: ↑Tue Jun 14, 2022 6:33 pm and the original files had attached to that topics, of coarse.
If you selected all of arrayX_small_Y as the Source of your View, and now you want (all-1) to be the Source, you need to press the ellipsis (...) at the right of the Source line in the PropertyEditor and deselect the array you no longer want.
Recompute is either right click in the object tree or use Std_Refresh button.
thanx.
the toolbar with recompute was not installed by default view.
but after i had install it, and had highlighted all bodyes, the recompute button still inactive and what mistake i had make this time?
and does it right, that in spate of i had set the decimal as 1, there are printed 2 decimals?
- 2022-06-15 00_06_31-FreeCAD 0.19.png (179.79 KiB) Viewed 488 times
- array2_size.FCStd
- (215.61 KiB) Downloaded 13 times
- 2022-06-14 23_57_59-FreeCAD 0.19.png (108.36 KiB) Viewed 494 times
and i'm worried about one more thing:
except the new inserted cells didn't appeared in techdraw page old view,
but dimensions distorted and lost their values.
i don't understand, why it happened, because of cells removing was in the middle, so the vertices,on which is dimensions is based,
are didn't touched, because they are had keep stay on the place.
