[FIXED] Distances in Projection Group
kaktus
Post by kaktus »
This dysfunction can be counted as an error. :roll:
The Projection Group panel has options for specifying the position of individual projections among themselves.
The "Spacing X" option works fine for me. However, the "Distance Y" option is a real magic.
Determining the vertical position of individual projections has nothing to do with the declared parameter.
The error occurs in all versions of FreeCAD (AppImage) that I have used recently.
My current version is:
OS: Debian GNU/Linux bookworm/sid (KDE/plasma)
Version: 0.20.29085 (Git) AppImage
Branch: (HEAD detached at 1e96bbd)
Hash: 1e96bbd2815683d6afa0afe8f985cdd04ef839fe
Python 3.10.4, Qt 5.12.9, Coin 4.0.0, Vtk 9.1.0, OCC 7.5.3
Locale: Polish/Poland (pl_PL)
https://vimeo.com/719514550
Roy_043
Re: Distances in Projection Group
Post by Roy_043 »
File?
kaktus
Post by kaktus »
There you go:
uchwyt_Redmi-10_Meriva_czesc3.FCStd
(429.52 KiB) Downloaded 18 times
However, the problem is not tied to this one project.
Roy_043
Post by Roy_043 »
Wrong file?
kaktus
Post by kaktus »
I'm still working on this project.
kaktus
Post by kaktus »
Should I restore the previous progress status for you?
Roy_043
Post by Roy_043 »
No, but this does not help of course.
Confirmed. See the attached file. I also changed the shape color. Black is too confusing.
Notice that the Right view seems to have a different height as well.
(436.91 KiB) Downloaded 14 times
kaktus
Post by kaktus »
Yes,
I can see the flaw, it's definitely a scaling problem. The size of the element frame is also different.
I talked about these problems earlier with Chris but I didn't want to burden him additionally before releasing the official version 0.20.
kaktus
Post by kaktus »
I expect you are using a different version of FC than the latest. :?:
The projections you created have different line attributes. FreeCAD in older versions had these settings by default.
Note the picture in my first post. It does not have the effect you pointed out.
wandererfan
Post by wandererfan »
kaktus wrote: Sun Jun 12, 2022 7:29 am The Projection Group panel has options for specifying the position of individual projections among themselves.
The screen grab shows you have "Auto Distribute" checked. This will position the Views based on the bounding rectangles of the largest View in each row/column. The SpacingX and SpacingY values modify the calculationed positions, generally to more widely space the Views.
