[TD] Suggestion for centerline improvement
balrobs
Post by balrobs »
When I add a centerline to a detail-view and extend it with the extend-line tool I notice that it's possible to extend it over the round draw-limits of the detail view. When doing so I see an interrupted centerline and an increased rectangular detail frame.
I would expect the centerlines not to exceed the round draw-limits and not to influence the size of the rectangular detail frame.
Do my expectations make sense?
Kind regards
OS: Ubuntu 20.04.4 LTS (ubuntu:GNOME/ubuntu)
Version: 0.20.27936 (Git) AppImage
Branch: (HEAD detached at 66f3474)
Hash: 66f34746c8e8e2b18f308d705b6a98d9d6942791
Python 3.9.10, Qt 5.12.9, Coin 4.0.0, OCC 7.5.3
  * Plot 2022.4.17
  * Reinforcement
  * CfdOF 1.14.5
  * FreeCAD_SketchArch
  * dodo
  * Curves 0.3.0
Re: [TD] Suggestion for centerline improvement
balrobs wrote: Sat May 14, 2022 1:31 pm Do my expectations make sense?
Sort of. On the other side: don't do it and everything is ok.
I don't have a sensible application at hand, but I can imagine some alignment where it can be sensible to align center lines across views.
balrobs
Post by balrobs »
Thanks @chrisb for your answer.
chrisb wrote: Sat May 14, 2022 5:10 pm Sort of. On the other side: don't do it and everything is ok.
The reason why I did it was to optain a better looking detail view.
Take my detail 2 as an example. When I select the two external vertical lines of the column and apply the extend-cosmetic-line comand with a default Extend-By value of 3,00 mm I end up with this:
Extending the centerline below the plate would make the detail clearer ... the centerline could belong also to the plate and the anchors.
But when I do so I encounter the already mentioned problem:
As a workaround I thought to use 3 centerlines. One for the column, another for the plate and the last for the anchors but this seems very cumbersome to me :roll:
Cheers
