Dimensions not displaying correctly
When dimensioning in Techdraw dimensions show up as shown. I have to change the measure type property value from projected to true in order to have the dimension display correctly. Is the a preferences setting that will overcome this problem. I have Freedcad 0.19 and 0.20 Win 64 bit versions and the problem is the same.
- Dimension display.png (13.63 KiB) Viewed 866 times
- wandererfan
Re: Dimensions not displaying correctly
You'll get a better answer if you can post the FCStd file demonstrating the problem. The dimension looks like both end points (Refernces2D property) are the same point. Is it a 2 point dimension or an edge dimension?ddhunt16 wrote: ↑Tue May 10, 2022 10:20 am When dimensioning in Techdraw dimensions show up as shown. I have to change the measure type property value from projected to true in order to have the dimension display correctly. Is the a preferences setting that will overcome this problem. I have Freedcad 0.19 and 0.20 Win 64 bit versions and the problem is the same.
Thankyou for the response.
FCStd file demonstrating the problem is attached. The dimension error occurs for both a 2 point dimension and an edge dimension.
- Fish Tank Stand.FCStd
- (103 KiB) Downloaded 20 times
I can reproduce the effect here. It vanishes immediately if I set KeepUpdated=True. Even when switching back it remains correct.
- wandererfan
The highlighted dimension in the picture has corrupt references. It is trying to measure from Edge5 to Vertex35, but there is no Vertex35 in View007. You should see a message in the Report View - "19:42:07 DVD::getDimValue - Dimension007 - 2D references are corrupt (5)"
There is an enhancement coming that will allow easily changing the reference points for a dimension, but for now, you'll have to delete the dimension and recreate it with valid references.
- DimCorruptReference2D.png (14.61 KiB) Viewed 716 times
Thankyou for picking up the corrupt references. I will pay closer attention to the error reports in the future.
