Position of Annotation not recomputed
In the attached model is the position of the annotation defined by expressions, which make it move together with the view. However, if the view is moved, no recompute is triggered and the annotation is not flagged for recompute. A manual recompute works.
To reproduce:
- Open the file
- Move View with the mouse
-> It needs a manual recompute of Annotation to reposition it.
AnnotationPositionExpression.FCStd
(4.97 KiB) Downloaded 39 times
Shalmeneser
Re: Position of Annotation not recomputed
Post by Shalmeneser »
A TechDraw_RedrawPage is not enough. A recompute is needed.
Version: 0.20.28717 (Git)
Python 3.8.13, Qt 5.12.9, Coin 4.0.0, OCC 7.5.3
Locale: French/France (fr_FR)
  * fasteners 0.3.40
  * Manipulator 1.4.3
  * sheetmetal 0.2.49
ragohix769
Post by ragohix769 »
I confirm.
It needs the total selection to re-compute, and then re-compute manually, redraw it's not working.
OS: Ubuntu 20.04.4 LTS (KDE/plasma)
Version: 0.20.
Branch: unknown
Hash: fe5ac277a017413a8646b621d5b993b0c606d551
Python 3.8.10, Qt 5.12.8, Coin 4.0.0, OCC 7.5.2
Locale: Italian/Italy (it_IT)
  * BIM 2021.12.0
wandererfan
Post by wandererfan »
chrisb wrote: Sun May 01, 2022 9:07 pm However, if the view is moved, no recompute is triggered and the annotation is not flagged for recompute.
I can change the code so Annotation is "touched" and the recompute button is enabled, but I can't get Annotation to recompute automatically.
Is the expected behaviour that Annotation be recomputed automatically or is having to push the recompute button normal?
wandererfan
Shalmeneser wrote: Mon May 02, 2022 9:32 am A TechDraw_RedrawPage is not enough. A recompute is needed.
Redraw updates the graphics with the current state of the objects. In this case, the Annotation object needs to update itself with the result of the expression.
wandererfan wrote: Mon May 02, 2022 3:42 pm Is the expected behaviour that Annotation be recomputed automatically or is having to push the recompute button normal?
Automatic recompute is not needed, perhaps even not desired, because of other time consuming stuff. Just flagging for recompute would fit well to other TechDraw things, which don't do the recompute immediately.
wandererfan
Should be fixed by git commit ccc8ac65c5.
wandererfan wrote: Mon May 02, 2022 9:54 pm Should be fixed
Thanks!
wandererfan
I'm going to revert this change. It is causing issues with unnecessary recomputes and redraws for linked Views such as Details and Sections.
We look at this again in the v0.21 cycle. Created issue #6943 so we don't forget.
user1234
Post by user1234 »
The CI from the PR#6942 (https://github.com/FreeCAD/FreeCAD/pull/6942) seems to stuck. Compiles fine here. Also the recomputing issue is gone. As expected the annotation recompute bug is risen again.
OS: Debian GNU/Linux 11 (bullseye) (X-Cinnamon/lightdm-xsession)
Version: 0.20.28951 (Git)
Branch: fixDoubleDraw
Hash: 91baa16c9bc148c8862e148efb8b20c3de4d756b
Python 3.9.2, Qt 5.15.2, Coin 4.0.0, OCC 7.6.2
Greetings
user1234
