TechDraw and v0.21
- wandererfan
TechDraw and v0.21
I've updated the TechDraw roadmap with my plans for v0.21. As always, plans are subject to change.
Your comments and suggestions are most welcome.
Re: TechDraw and v0.21
Looking forward to the changes. All sound sensible.
Maybe add a TechDraw_ExportPagePDF button to the TechDraw File Access toolbar? I know this option is available via the context menu, but adding this button would make sense I think.
This can be a very important feature to include in 0.21:
https://forum.freecadweb.org/viewtopic. ... 1&start=20
The tool seems to be pretty much ready and it’s just a matter of implementing it.
Do you mind linking each existing GH ticket in the wiki page at your convenience?wandererfan wrote: ↑Thu Apr 28, 2022 2:09 pm I've updated the TechDraw roadmap with my plans for v0.21. As always, plans are subject to change.
- wandererfan
This toolbar? I'm not really happy with the rmb context menu. The first 2 items are ok, but the 3 export options seem out of place.
Yes. AFAICT the TechDraw WB has 3 export options (*.svg, *.dxf, *.pdf), but this toolbar only shows two.
I will try to perform this task.NewJoker wrote: ↑Thu Apr 28, 2022 4:28 pm This can be a very important feature to include in 0.21:
There is an issue: the task creates a (surface finish) symbol, represented by a small svg file as a string. The symbol becomes connected to the page, not to the view. If the view is moved, the symbol is not moved.
Is it possible to connect a symbol to a view ?
If not, is it possible to implement this ?
- wandererfan
That would be great.edi wrote: ↑Sat Apr 30, 2022 7:13 am I will try to perform this task.
To connect the symbol to the view, you would add a QGCustomSvg to the QGIViewPart. We do this for Svg hatches on QGIFace. Also see QGIViewSymbol which is just a view with an embedded Svg image.
In Python, TechDrawGui.addQGIToView(myFeature, myQGSvgItem) should do it. If not, we can add some functionality.
