Hello everyone, I seem to have a problem with the software. I can't find the way to do a hole to hole dimension. Some people call it center-to-center.
I tried using the techdraw extension. I tried using drawing dimensioning extension as well where there is the option, to mark the center of a hole but sadly the app seems to be stuck there. I select the function center mark, click on the hole i made, but it doesn't appear and just stays stuck there.
Help - can't do a hole to hole dimension from center
- Catacombs Lord
- wandererfan
Re: Help - can't do a hole to hole dimension from center
Like this? Arc centers can be used just like vertices as the end points of a Dimension.Catacombs Lord wrote: ↑Tue Jan 11, 2022 1:24 pm Hello everyone, I seem to have a problem with the software. I can't find the way to do a hole to hole dimension. Some people call it center-to-center.
As for the app being stuck, that's hard to evaluate without a sample fcstd file.
- Catacombs Lord
Thanks for the help!
I finally figured out that the drawing option ''Turn View frames Off'' has to be -ON- in order to SEE the center marks. Otherwise you won't see them..
Can you post how to get to the drawing option ''Turn View frames Off''. I can't find it.
Thanks,
Steve
Thanks,
Steve
with this page TechDraw_Workbench, you have all the tools with a brief description of they are doing.
