Move view or section to another page
Hello FreeCAD Community,
if you create a page with the TechDraw workbench and add different views, sections or details, is it possible to shift these objecs to another page?
Re: Move view or section to another page
This is not possible and a known limitation:
https://wiki.freecadweb.org/TechDraw_Wo ... imitations
(last point)
by the way, to tell us your FreeCAD version, just click in the About dialog on "in die Zwischenablage kopieren" and then paste to your post.
(last point)
Thank you @uwestoehr for the quick reply.
It is really a pity that it is sometimes difficult to adjust the layout of TechDraw "page" objects afterwards. This implies that before you start compiling, measuring and labeling drawings, you have to have exact ideas about how the result should look like or you do part of the work twice.
For now, that's the way it is.
I really appreciate your help. Thanks.
System information:
Version: 0.20.26683 (Git)
Python version: 3.8.12
Qt version: 5.12.9
OCC version: 7.5.3
System information:
Qt version: 5.12.9
OCC version: 7.5.3
It can be done but is a bit tricky. Please report back if it works for you:
- select Page2
- select the value of Views
- click the button occurring at the right
- select the view(s) you want to move in the upper window and confirm
- do the same with Page1, now removing the items
- recompute (not sure if this is needed)
- (now it becomes cumbersome) save the file and reopen it
The views are moved.
Hi @chrisb,
GREAT!!! The described method works (nearly perfect). Thank you very much.
You can add the desired view to "page_2" and it will appear there immediately.
Then you can remove the view from "page_1". But, as you said, the changes on page_1 appear only after the file is saved, closed and reopened.
I really appreciate the quick help on this topic. Thanks.
- wandererfan
TechDraw_MoveView and TechDraw_CopyView
git commit 5a40cd0a
These are the first TechDraw commands written in Python, so please report any oddities you encounter.
git commit 5a40cd0a
I notice two issues:
Path to the ui files is incorrect in TaskMoveView.py and TaskCopyView.py.
I had to change "Mod/TechDraw/Gui/.." to "Mod/TechDraw/TechDrawTools/.."
After using TechDraw_CopyView there is a warning:
View belongs to multiple Pages
Version: 0.20.27271 (Git)
Hash: f045a0b6f12ec82c0ddb44570c81dfcc3940af0d
Python version: 3.8.6+
Qt version: 5.15.2
Coin version: 4.0.1
OCC version: 7.5.3
- wandererfan
In my build environment, the ui files are in "Mod/TechDraw/Gui" but in freecad-daily they are in "Mod/TechDraw/TechDrawTools". My CMake scripting skills are rudimentary at best. Might need to hunt up some consulting help.
This is just a reminder. After a copy, there is still only 1 View, but 2 Pages "own" it. So any changes made to the View from either Page will show on both Pages.Roy_043 wrote: After using TechDraw_CopyView there is a warning:
Thanks for the feedback.
I actually read to Wiki documentation before using the tool, and still find the message confusing. My interpretation was: The code is doing something that is not allowed. I realize the color of the message would then be red instead of orange, but still.
I can also imagine that users create a copy with the intention of modifying it. Enabling that option, and adding a "Create linked views" toggle may be a good idea.
- wandererfan
Making a new independent view is harder.
I'm hesitant to use "linked" because it might lead to confusion with @realthunder's links. Maybe what I called "Copy View" should be "Clone View", or maybe "Create shared view"?
