I'm not up to speed on the new CI process yet (what used to be Travis and is now Gitlab?). I think I'm waiting on Bernd to return from holiday?
collection of page issues
- wandererfan
Re: collection of page issues
Bernd is already back and the CI is running -> I'll send you a private message to inform you.wandererfan wrote: ↑Fri Dec 31, 2021 3:34 pm I'm not up to speed on the new CI process yet (what used to be Travis and is now Gitlab?). I think I'm waiting on Bernd to return from holiday?
- wandererfan
Is there a bug report or forum topic for the crash? I need to modify the fix to allow clean up of the page when a view is moved to a new page and I don't want to reintroduce what you fixed.TheMarkster wrote: ↑Mon Dec 13, 2021 12:59 am Does the same issue happen in 0.19? The reason I ask is when I added the Use Original Selection to the edit menu -> copy / edit menu -> duplicate dialog (new for 0.20) it revealed a crash when using it to duplicate techdraw pages. I submitted a fix to prevent the crash, but it could have had some unintended effects.
I didn't know enough about techdraw code to do a proper fix (and still don't), but this seemed to work at least to stop the crash. My concern was it might cause some unintended effects.wandererfan wrote: ↑Fri Jan 07, 2022 5:28 pmIs there a bug report or forum topic for the crash? I need to modify the fix to allow clean up of the page when a view is moved to a new page and I don't want to reintroduce what you fixed.TheMarkster wrote: ↑Mon Dec 13, 2021 12:59 am Does the same issue happen in 0.19? The reason I ask is when I added the Use Original Selection to the edit menu -> copy / edit menu -> duplicate dialog (new for 0.20) it revealed a crash when using it to duplicate techdraw pages. I submitted a fix to prevent the crash, but it could have had some unintended effects.
There were 2 PR's:
https://github.com/FreeCAD/FreeCAD/pull/5013
https://github.com/FreeCAD/FreeCAD/pull/5016
This is the one with the Original Selection button, but it has no specific techdraw changes. It was there that it was discovered duplicating a page without its contents caused a crash and how to reproduce. (Note that the crash also happened in 0.19, but then it wasn't as easy to duplicate the page without the contents because you had to alter the selections in the duplicate dialog.)
https://github.com/FreeCAD/FreeCAD/pull/5010
- wandererfan
I built a version without your change to MDIViewPage, but I can't make it crash. Must not be following the right steps.
Open this file. Select the Page, in edit menu -> duplicate selection. In the dialog select only the page as shown in this screenshot:wandererfan wrote: ↑Sat Jan 08, 2022 1:39 pmI built a version without your change to MDIViewPage, but I can't make it crash. Must not be following the right steps.
After pressing OK you should get a crash (FreeCAD exists without explanation). I was able to reproduce a crash with 0.19, but I didn't update to the latest 0.19 release, which does include some backported bug fixes. Here is the version that crashes:
Version: 0.19.24267 (Git)
Hash: b2ca86d8d72b636011a73394bf9bcdedb3b109b7
Python version: 3.8.8
It might also crash with the Use original selections button (without my fix), but that button is not available in 0.19.
- techdraw_crash.FCStd
- (15.82 KiB) Downloaded 19 times
The crash is also in FC 0.19.3 because the fixes were not backported. Can you please in future add a post to our backport thread for commits/PRs that should be backported:TheMarkster wrote: ↑Sat Jan 08, 2022 5:44 pm After pressing OK you should get a crash
https://forum.freecadweb.org/viewtopic.php?f=10&t=57659
I backported now these PRs:
I will now compile and see if the crash is then gone. This takes however, about an hour.
