Hello
I'm working on big structures and I can't take smaller scale then 0,01. I need 0,005 or 0,001. Any ideas?
Best regards
Marcin
To big structures
To big structures
- x1.PNG (172.76 KiB) Viewed 1897 times
Re: To big structures
Expression for example: 1/1000
or
Edit --> Preferences --> General --> Units --> Number of Decimals
Greetings
user1234
or
Greetings
user1234
Increase the number of decimals in Preferences->General->Units. If you enter a smaller value then it will not be shown on the GUI, but it will still be set. This may be helpful for a quick test, but sure not for a permanent solution.
Edit: User1234 was faster ...
Thank you for help!
You can write an expression in Scale (eg 0.001) but you will see only 2 decimal digits (you see 0.00).
=0.001
