Is possible to make dimension values as Italic font style?
In accordance with GOST standards, the dimensions are indicates mainly in italics.
Re: Is possible to make dimension values as Italic font style?
In my country, the IRAM 4503 standard based on the ISO 3098 standard also makes it possible to use inclined or italic letters. The default font in FreeCAD is osifont, but I haven't found a way to make it italic with techdraw. Maybe there is a macro or code to be able to do it, but ideally there would be in preferences the option to have the fonts in italics whatever one chooses.
- iram4503_0.png (63.67 KiB) Viewed 2306 times
- wandererfan
Not possible in current versions. Would this setting apply to all dimensions, or does it need to be adjustable for individual dimensions? A bit less work if it applies to all dimensions,
In my case, yes, it would be applied to all the dimensions of the page that is being worked on. That's why I think it should be in the TechDraw preferences. Even better if the labels of the templates also came with said type of italic font.
I think it should be possible with individual characters within a dimension. See Fig. 29 of ISO129-1:2018 as an example.wandererfan wrote: ↑Sat May 14, 2022 3:37 pm ...Would this setting apply to all dimensions, or does it need to be adjustable for individual dimensions?
We have to be careful about mixing standards: ISO 3098 is for lettering on technical documents in general. ISO 129 is more narrowly focussed on dimensions.
Preferably for each label separately and so that you can customize the default style in the settings.wandererfan wrote: ↑Sat May 14, 2022 3:37 pmNot possible in current versions. Would this setting apply to all dimensions, or does it need to be adjustable for individual dimensions? A bit less work if it applies to all dimensions,
Opening the file A4_Portrait_ISO7200TD.svg in Inkscape shows that the text is in osifont italic.
Why does it look Normal in FreeCAD?
Version: 0.21.30492 (Git)
Hash: b4578fb3eae842eb510a1bc055d07d369a67ce94
Locale: Spanish/Argentina (es_AR)
* A2plus 0.4.59c
* Curves 0.5.8
* DynamicData 2.46.0
* fasteners 0.4.12
* sheetmetal 0.2.57
For a correct display in Inkscape you need to install the osifont. Have you done that?
- wandererfan
Is this a custom template? If it is, please post it and I will have a look.
My copy of A4_Portrait_ISO7200TD.svg does not use osifont.
- A4_Portrait_ISO7200TD.png (69.95 KiB) Viewed 1474 times
