Macro version 4.2 multilanguage: helper tools to improve TechDraw documents.
Re: Macro version 4.2 multilanguage: helper tools to improve TechDraw documents.
Is there a way to control the position of the baseline for coordinate dimensions?
In the example on the TechDraw_ExtensionCreateObliqueCoordDimension page the baseline is at vertex 4, is there a way to put it at vertex 1?
Hi Roy_043, greetings to the Community!
Currently, when for me it is necessary, I intervene from the properties of the dimension by assigning to the dimension new references to the vertices, in the * .gif (for newbies) the steps to do so are shown.
I believe that @edi should have no particular problems in solving (?) This (important) "detail" in integrating the code of the macro functions in TechDraw
- Change of reference vertices of parallel coordinate dimension.gif (712.12 KiB) Viewed 3027 times
Thanks for showing this workaround. I was actually not aware that you can update links in the Link dialog by clicking in the 3D view. So thanks for that as well.
The workaround in the existing Create Horizontal Coordinate Dimensions tool:
- Sort all selected vertexes by its x-coordinates
- Create dimensions from the first (leftmost) vertex to the second, the third etc. vertex.
IMO the most important matter is the user interface, which must be as comfortabe as possible.
I do not prefer a dialog in the Combo-View where the user has to click a left/right button.
My suggestion: To show the baseline the first selected vertex must be the leftmost or the rightmost one. If the first selected vertex is neither the leftmost nor the rightmost an error message occures.
Find attached a test macro using this workaround.
- Select several vertexes
- Start the macro
Horizontal coordinate dimensions are created:
- If the first selected vertex is the leftmost, the baseline is at the left
- If the first selected vertex is the rightmost, the baseline is at the right
- If neither nor, an error message occures.
''' Testmacro creating a horizontal coordinate dimension using a left or right baseline'''
import TechDraw
import FreeCAD as app
import FreeCADGui as gui
class commonTools:
''' common tools used by command buttons'''
def selectionOK():
''' check selection of View and ObjectList '''
OK, ObjectList, View = False, [], []
if gui.Selection.getCompleteSelection():
View = gui.Selection.getCompleteSelection()[0]
ObjectList = gui.Selection.getSelectionEx()[0].SubElementNames
if len(ObjectList) > 0:
OK = True
return (OK,ObjectList,View)
class createHorizChamferDim:
'''Create horizontal chamfer dimension'''
def activated(self): # createHorizCoordDim
def sortVertex(Vertex):
return Vertex.Point.x
(OK,ElementNames,View) = commonTools.selectionOK()
if OK:
VertexNames = [VertexName for VertexName in ElementNames if VertexName[:6]=='Vertex']
Vertexes = [View.getVertexBySelection(VertexName) for VertexName in VertexNames]
firstSelect = Vertexes[0]
Vertexes.sort(key=sortVertex)
if firstSelect == Vertexes[0] or firstSelect == Vertexes[-1]:
if firstSelect != Vertexes[0]:
Vertexes.reverse()
if len(Vertexes) > 1:
XPos = float(Vertexes[0].X)
YPos = float(Vertexes[0].Y)
Sign = YPos/abs(YPos)
for i in range(len(Vertexes)-1):
DistanceDim=TechDraw.makeDistanceDim(View,'DistanceX',Vertexes[0].Point,Vertexes[i+1].Point)
DistanceDim.X = (XPos+Vertexes[i+1].Point.x)/2
YPos = YPos + 7*Sign
DistanceDim.Y = YPos
gui.Selection.clearSelection()
else:
print('First vertex must be the leftmost or rightmost one')
execute = createHorizChamferDim()
execute.activated()
- Start the macro
You can also check the order of the first two vertices. That would perhaps make more sense as these also determine the direction (angle) of the TechDraw_ExtensionCreateObliqueCoordDimension tool AFAICT.
OK, good idea. Find attached a test-macro using the suggested workaround:
- Select several (at least two) vertexes.
- Start the macro.
- If the first selected vertex is left of the second one, the baseline is at the left
- If the first selected vertex is right of the second one, the baseline is at the right
import TechDraw
class commonTools:
def selectionOK():
OK = True
if OK:
secondSelect = Vertexes[1]
if firstSelect.X > secondSelect.X:
Vertexes.reverse()
execute.activated()
- Start the macro.
Yes it works quite well. Thanks.
This macro is really good! Many (probably all, but I've not used all the tools in the toolbox yet) of the features here should be part of baseline FreeCAD.
There's one thing that I'm sure is in front of me, but I can't see: how do I center a dimension label over the dimension line? I'm sure there will be a way, I just can't find it.
All the tools are created in C++, a PR https://forum.freecadweb.org/viewtopic.php?f=17&t=63548 is waiting to become merged.
Sorry, no option in the macro tools, but that will be possible in the C++ version.
I just saw that (all? most?) of the tools are finally merged into master, and they're already present in the latest dev appimage. Great work!
I didn't see it yet, but is there now a way to center a dimension over the the dimension line? or is this waiting for the merge to stabilise?
EDIT: DOH, using the "Extensions: Attributes/Modifications"/ "Position Horizontal Chain Dimensions"|"Cascade Horizontal Dimensions" will center the dimension over the dimension line, even if only one dimension is selected. Vertical centering seems to not work properly, since the dimension seems to end up slightly offset towards the bottom. Will detail it in a later post.
Oh, and I see that you've added "add diameter symbol" and "add square tube symbol". I've been using this macro https://github.com/reox/FreeCAD_macros/ ... at.FCMacro to add other symbols to my dimensions. Maybe it would be a good thing to incorporate (some? all?) of these into this drop down?
