Macro version 4.2 multilanguage: helper tools to improve TechDraw documents.
Re: Macro version 4.2 multilanguage: helper tools to improve TechDraw documents.
Thank you very much for the answer and the job.
To draw Thread lines :
- Create a sketch with the future lines (Z-offset to be outside and visible)
- Select (the view + this sketch) for your TechDraw
- Modify line with TechDraw_DecorateLine
- Do the dimensioning
- Thread line.FCStd
- (22.45 KiB) Downloaded 82 times
- Snip macro screenshot-26a1b8.png (19.42 KiB) Viewed 4580 times
- Snip macro screenshot-631539.png (8.05 KiB) Viewed 4580 times
- Snip macro screenshot-0d0e78.png (11.24 KiB) Viewed 4580 times
A new, extended version has arrived in github https://github.com/FreeCAD/FreeCAD-macr ... ls.FCMacro and can be downloaded using the Extension Manager WB or the Aplication manager.
New added tools:
- create an oblique dimension chain
- create oblique coordinate dimensions
- position an oblique dimension chain
- cascade oblique dimensions
A 5-th tool calculates the area of a closed line chain, and inserts the value as an Annotation. This tool is a preliminary version, not checking wheter the line chain is closed. Be carefully using it.
PS. I am working on the integration into TechDraw WB, hopefully a PR creating the first tools can be started in some days.
New added tools:
- ragohix769
You are a hero
I've submitted a minor PR https://github.com/FreeCAD/FreeCAD-macros/pull/106 if you've merge permissionsedi wrote: ↑Tue Jul 20, 2021 5:28 am A new, extended version has arrived in github https://github.com/FreeCAD/FreeCAD-macr ... ls.FCMacro and can be downloaded using the Extension Manager WB or the Aplication manager.
Once again: Thank you very much! I still have features to test
Regards / Viele Grüße
Max
Max
https://github.com/FreeCAD/FreeCAD-macr ... ls.FCMacro :
__Version__ = '0.4.4'
self.setWindowTitle("TechDrawTools V- 0.4.3-multilanguage")
Hence my PR above, the version number should only need to be updated in one placeShalmeneser wrote: ↑Tue Jul 20, 2021 8:49 am https://github.com/FreeCAD/FreeCAD-macr ... ls.FCMacro :Code: Select all
Hello Shalmeneser, good morning to the Community!Shalmeneser wrote: ↑Tue Jul 20, 2021 8:49 am ........................Code: Select all
Thanks for the report, we already knew about the inconvenience and for this we apologize.
We confirm that the version is 0.4.4.
To correct this, simply replace 3 with 4 in line 295.
