Macro version 4.2 multilanguage: helper tools to improve TechDraw documents.
Re: Macro version 4.2 multilanguage: helper tools to improve TechDraw documents.
Would it be sensible as a long term goal to integrate sketches into TechDraw documents, similar to how bodies handle them: It would be possible to use other points from a view as external references but nothing else.
And of course TechDraw should be aware of the Sketcher's geometric element "Point".
Hi chrisb
..... certainly the detection of the sketcher point in TechDraw, together with the workflow mentioned in the topic "TechDraw without limits = Layout autocad" and the macro "TechDrawTools-V_0.4.2" would allow us to create technical drawings without any limit.
- ragohix769
This tool is a game game changer for TechDraw!
It should be integrated in TechDraw default, IMHO.
BTW italian: [Grazie davvero per lo splendido lavoro che stai/state facendo ]
..... here's how to generate the multiple drilling table
- Create hole table.gif (995.5 KiB) Viewed 3567 times
.... the use of perpendiculars to dimension chamfers and angles in inclined objects
- Create_a_line_perpendicular.gif (746.55 KiB) Viewed 3530 times
..... use of the cosmetic circumference, for example to create parallels (the error signaling, for the modification of the attributes of the cosmetic lines, of FC does not affect the result)
- use of cosmetic circumference.gif (703.33 KiB) Viewed 3495 times
.... horizontal dimensions parallel coordinates and cascade spacing modification, for the vertical ones use the same procedure
- horizontal dimensions parallel coordinates.gif (242.6 KiB) Viewed 3491 times
- ragohix769
Incredible!!!
.... here is one of the solutions for tracing the tangent quota using the tools present in TechDrawTools 0.4.2-multilanguage: cosmetic circumference and perpendicular and vertex in the intersection, I understand that it is a bit laborious but in any case it succeeds
- Tangent dimension construction.gif (420.62 KiB) Viewed 3417 times
I love it! Drilling table is something I use the Spreadsheet view for today.
Regards / Viele Grüße
Max
Max
