[Solved] ArchView only shows objects if section plane cuts through them
bitacovir
Post by bitacovir »
I created a Section plane on a cube in ArchWB
Then, I created a ArchView from that section plane in Techdraw
When the section plane cuts the cube, the ArchView shows the section of the box in the Techdraw.
But if I move the section plane outside of the cube, the ArchView does not show anything.
Section plane cutting the box
section plane no cutting the box
Version: 0.19.22411 (Git)
Hash: d4519d5aec15bc08f029da5ed15410a494b57b2c
Python version: 3.8.5
Qt version: 5.12.6
::bitacovir::
My personal web site
My GitHub repository
Mini Airflow Tunnel Project
domad
Re: ArchView only shows objects if section plane cuts through them
Post by domad »
bitacovir wrote: Tue Sep 15, 2020 6:08 pm I created a Section plane on a cube in ArchWB
FC Version: 0.19.22411 (Git)
Hello bitacovir
The cut is visible at a maximum distance of 1.00 mm.
No sight at 1.10 mm
I hope I helped you solve the "mystery"
bitacovir
Post by bitacovir »
domad wrote: Thu Sep 17, 2020 8:57 pm
Hello bitacovir
No sight at 1.10 mm
I use the Section plane to create ArchViews of building facades... The plane is several centimetres or meters from the walls. still it is not working...
::bitacovir::
vanuan
Post by vanuan »
Seems like a bug in the Arch view rendering engine. Which render mode do you use? It looks like Wireframe and Solid have this issue, while Coin renders it properly.
Is it a regression? Maybe it never worked? Cube isn't an architectural object, after all.
domad
Post by domad »
vanuan wrote: Fri Sep 18, 2020 3:41 am
Greetings to the whole community!
I think there is nothing unusual, you need to be a little more "inventive" ..... can you do the same or not? ;)
This is the result of what I explained earlier ...
I hope I was clearer
vanuan
Post by vanuan »
domad wrote: Fri Sep 18, 2020 7:55 am Greetings to the whole community!
I don't understand what you're telling. Clearly, walls are displayed but the cube is not. Are you saying it is because the cube is very small?
domad
Post by domad »
vanuan wrote: Fri Sep 18, 2020 8:36 am I don't understand what you're telling. Clearly, walls are displayed but the cube is not. Are you saying it is because the cube is very small?
Hi "vanuan", pleasure of knowledge, the cube is absolutely visible even if very small, I was just pointing out a way around the bitacovir problem:
"I use the Section plane to create ArchViews of building facades... The plane is several centimetres or meters from the walls. still it is not working..."
bitacovir
Post by bitacovir »
yes I have the problem with Wireframe rendering.
Section planes used for facade rendering with ArchView in TechDraw has been used as normal workflow by Yorik and me. You can verify it in this chapter of the Manual BIM modeling: https://wiki.freecadweb.org/Manual:BIM_modeling
Also, you can verify with the ArchDetail model included as example file in FreeCAD installation. In this model, the Section A is to display an elevation view:
I have tested this example model in two freeCAD installations: 0.18.4 and 0.19 creating a TechDraw page and an archView without any manipulation of the model. It works fine in the first case, but it does not work in the second installation.
OS: Windows 10
Version: 0.18.4 (GitTag)
Branch: releases/FreeCAD-0-18
Python version: 3.6.6
Qt version: 5.6.2
Qt version: 5.12.6
::bitacovir::
vanuan
Post by vanuan »
bitacovir wrote: Fri Sep 18, 2020 12:29 pm
vanuan wrote: Fri Sep 18, 2020 3:41 am Is it a regression? Maybe it never worked? Cube isn't an architectural object, after all.
Ok. A regression then. I can reproduce the issue in the AppImage version from around June 20.
Which means a regression happened not later than in May:
https://github.com/FreeCAD/FreeCAD/comm ... onPlane.py
Here's a start of the Wireframe rendering code
https://github.com/FreeCAD/FreeCAD/blob ... ne.py#L455
Let's see whether there's something obvious.
domad
Post by domad »
....here are the experiments I tried, they could be useful to solve the problem
