If there is consensus on this feature, then I may work to help implement it.You can use a broken (or interrupted) view in a drawing. Broken views make it possible to display the drawing view in a larger scale on a smaller size drawing sheet. You create a gap or break in the view using a pair of break lines. Reference dimensions and model dimensions associated with the broken area reflect the actual model values.
Feature #3011 - TD broken view
Techdraw would benefit from a similar feature such as that shown here: http://help.solidworks.com/2012/English ... K_VIEW.htm
Reason: Added ticket number to thread title
Re: Proposed feature: broken view
Would sure be good to have. It was already mentioned several times.
is there an open issue in the tracker ?
- wandererfan
- thebighaggis
I vote for that too
Would be very handy on a job I'm doing right now..
I had to use Inventor to do the drawing..
Cheers
Haggis
Cheers
Haggis
- Broken View.jpg (71.36 KiB) Viewed 3147 times
Re: Feature #3011 - TD broken view
This has been a Feature request for a while. I'm sure people would like to see this implemented. Are you going to take a stab at it?
Please up again for this feature possibly in FreeCAD in 2023ggarner wrote: ↑Wed Jul 15, 2020 1:46 pm Techdraw would benefit from a similar feature such as that shown here: http://help.solidworks.com/2012/English ... K_VIEW.htm
