Missing lines - Section view of multiple bodies
I have a problem how to create a section view.
1.I draw 2 bodies
2. I make a view
3. I make a section view
Freecad does everything Ok but do not draw lines where the bodies touch i.e. they are hidden behind hatch. Both bodies have the same hatch?
I don't know if I'm wrong or ... Look at the picture and the file
OS: Windows 7 SP 1 (6.1)
Version: 0.19.18719 (Git)
Hash: c021ff70debb106b27d03ed1707f4b05fcf385a6
Python version: 3.6.7
Qt version: 5.12.1
1.I draw 2 bodies
2. I make a view
Qt version: 5.12.1
- test.FCStd
- (23.32 KiB) Downloaded 47 times
- 2019-12-30_213213.jpg (101.65 KiB) Viewed 2048 times
- 2019-12-30_213120.jpg (111.51 KiB) Viewed 2048 times
Re: Missing lines - Section view of multiple bodies
FYI, you are using an obsolete 0.19 revision. Right now we're at r19111 for Windows. Please test again and report back.
I tried on the latest version but I get the same. I have watched various techdraw tutorials but no one makes drawings for multiple bodies or assemblies.
Version: 0.19.19111 (Git)
Hash: a9f820470b8a0df72291b99e66ea14e0dc8c2164
Python version: 3.7.3
- wandererfan
FuseBeforeSection, nice, its working. Thank you. Is there a way to set this as the default setting?
One more thing if you have time. Both bodies have the same hatch, can techdraw module automatically put different hatch (i.e. same but at different angle or scale). I know how to manually do this, but it's quite tiring when you make a cross-section of multiple bodies with more complex geometry.
I hope I have helped with these issues not only to me but also to other people.
- wandererfan
You'll need to use the Parameter Editor (Tools > Edit parameters...) to set the default. If "Mod/TechDraw/General/SectionFuseFirst" exists and is set to "true", just change it to "false".
If "Mod/TechDraw/General/SectionFuseFirst" isn't there, you'll have to add a new "New Boolean item" for "SectionFuseFirst" and set it to "false".
No, all the cut surfaces get the same hatch. How would you decide programmatically which hatch to apply to which face? The only "rule" I know is if it looks funny, change the angle of one of the hatches.One more thing if you have time. Both bodies have the same hatch, can techdraw module automatically put different hatch (i.e. same but at different angle or scale). I know how to manually do this, but it's quite tiring when you make a cross-section of multiple bodies with more complex geometry.
Is there a way to prompt the user on their first usage of TD if this is something they want to enable by default?wandererfan wrote: ↑Tue Dec 31, 2019 1:58 pm You'll need to use the Parameter Editor (Tools > Edit parameters...) to set the default.
- wandererfan
If the user never does anything, this parameter defaults to true, which is the right choice most of the time.
Is this first use parameter check implemented anywhere?
Well, I've been using Techdraw for real world purposes since end of June 2017 and I've never needed to change/touch or know about this parameter but then if I'm drawing an assembly I wouldn't go about it as the OP suggests though there's nothing wrong with that method but then I use Blender alongside FreeCAD to help the fitters 'see' what's really going on with colours and transparency.
@Kunda1, I understand where you're coming from but there has to be a threshold when it comes to FreeCAD helping users out. I've just spent the past week learning rigging in Blender for real mechanical purposes, again to help the people assembling be able to move virtual parts around and see what the consequences of restricted access, pipe routing etc. There's been times when I've spent hours trying to get Inverse Kinematics do what I want but I persevered and now I understand (a lot more) as to how it works not just doing something parrot fashion. Maybe this is one area where we have differing views.
@Syres not to go too off topic, check out https://forum.freecadweb.org/viewtopic.php?t=36424 to see what I mean.
