[SOLVED] view solid colors in technical drawing
Is possible to represent views of a solid in a technical draw that preserve the object original colors? something like this:
- wandererfan
Re: view solid colors in technical drawing
Yes, but it isn't perfect or easy. You can apply an SVG hatch using the Solid pattern to any Face in the drawing TechDraw_Hatch.
The bad news. 1) You have to apply the hatch to each Face individually. 2) the Face finding algorithm in TechDraw is imperfect, so you might have an area that isn't recognized as a Face.
Re: [SOLVED] view solid colors in technical drawing
Not a perfect and easy solution, but function for now.
Note that using an Arch Section plane + Techdraw Arch View set in "Solid" rendering mode will produce colored views like the example above. But it is pretty buggy and will fail miserably with complex objects with a lot of curves...
@wandererfan, the current TD view already fills faces with white, right? An easy trick/fix would be to allow for the user to change this for another color...
- wandererfan
Yes, solid white fill unless there is a hatch assigned to the face. Adding a Property::Color to the ViewProvider would be an improvement over using a solid hatch on each face.
But somebody is sure to ask for different colors on different faces, no?
I've a suggestion: a technical draw is a very important tool for make easy understandable the manufacturing process and quality control of a large variety of products whose representations will be very different. In this sense we need mechanism to modify those representations: make drafts in it, modify "with one click" properties of individual or groups of points, lines, faces or bodies, texts. In example the following cases:
1. A gear arrangement draw have too much information, for simplify views we hide or paint white a group of lines and sketch some conventions.
2. Drawing fabric products we use colors in surfaces to differentiate distinct layers of materials and highlight individual lines that represent joints.
3. In large part lists commonly we need to modify a specific text box without the needing of recompute the whole table.
It's a very useful software! just pay more attention to the technical draw module. The examples bellow:
- inventor.PNG (47.67 KiB) Viewed 6930 times
- gear.png (20.94 KiB) Viewed 6930 times
Does this Feature Request merit a ticket ?
- wandererfan
Probably. But I'm not sure what the Feature Request actually is; easier color drawings, hide individual lines in the drawing, hightlight individual lines, don't recompute on text changes....
Don't see all that being done as one work package.
I'll split them in to 4 tickets then.wandererfan wrote: ↑Fri Aug 31, 2018 10:59 amProbably. But I'm not sure what the Feature Request actually is; easier color drawings, hide individual lines in the drawing, hightlight individual lines, don't recompute on text changes....
