Target Spreadsheet Aliased Cell Color through .qss? (FreeCAD 0.20.1)
Re: Target Spreadsheet Aliased Cell Color through .qss?
Axeia wrote: Tue Oct 04, 2022 2:50 pm ...
If changes are made to the FreeCAD code I'd be in support of simply adding a class named "alias" or "aliased" so themes can simply target it as
QTableView::item.aliased{
    background-color: teal;
It's a lot easier to read than the the whole "qproperty-AliasedCellBackgroundColor" syntax. It also makes it easier for people (like me) that have a CSS rather than a Qt Style Sheets background to understand what's going on.
Things are somewhat complex, as the whole "color change" and "color customization" is improving recently, as a lot of work is done in "color customization" and "many little places" where things are not so smoth are found and fixed.
From what I know about Qt changing QTableView::item setting will spread across FC even in places where maybe you will not know that is used, so probably some more verbose name has to be used, to refer maybe to a specific use of the QTableView widget, like the Spreadsheet alias you intend to change.
Probably trying to find some "meaningful names" that maybe use some abbreviations like AliasSSBckCol as a rough example will be a more "clever setting", as it could be retrieved and applied to a specific use of QTableView control.
But as UI is not my most known part of FC I leave to more skilled people to make such type of decision.
MisterMaker
Re: Target Spreadsheet Aliased Cell Color through .qss? (FreeCAD 0.20.1)
Post by MisterMaker »
            <FCText Name="ImportExportQuoteCharacter">"</FCText>
            <FCText Name="ImportExportEscapeCharacter">\</FCText>
            <FCUInt Name="aliasBgColor" Value="2105376255"/>
            <FCUInt Name="AliasedCellBackgroundColor" Value="2105376255"/>
Found the settings but they really screw up my markup, I wonder if this can impact the rest of the settings?
chennes
Post by chennes »
No, that's perfectly well-formed XML, it's just your XML formatter doesn't understand it correctly.
Chris Hennes
Pioneer Library System
chennes wrote: Tue Oct 04, 2022 3:57 pm No, that's perfectly well-formed XML, it's just your XML formatter doesn't understand it correctly.
No there is an additional double quote in the seventh line between closing and opening bracket: >"<
chennes
Post by chennes »
chrisb wrote: Wed Oct 05, 2022 7:59 pm No there is an additional double quote in the seventh line between closing and opening bracket: >"<
That's legal XML. It's a literal double quote character in that position.
Chris Hennes
MisterMaker
Could it because the colors aren't in the settings menu? I could remember something that this should be the case for it to be read?
chennes
Post by chennes »
Ahhh.... it's actually because the code for reading that color value is non-standard: it is expecting an ASCII string (it defaults to "#feff9e"), rather than an unsigned integer. So try using a hex code instead, and instead of FCUint for the type, use FCText. IMO we should change this, but of course doing so will break everyone's stylesheets.
Chris Hennes
MisterMaker
chennes wrote: Sun Oct 09, 2022 7:38 pm Ahhh.... it's actually because the code for reading that color value is non-standard: it is expecting an ASCII string (it defaults to "#feff9e"), rather than an unsigned integer. So try using a hex code instead, and instead of FCUint for the type, use FCText. IMO we should change this, but of course doing so will break everyone's stylesheets.
Noice, now we know what the issue is we can fix it! I kinda like the hex way more than the integer....
This:
            <FCText Name="AliasedCellBackgroundColor">#850097</FCText>
Changed it too purple!
Ok my extremProDark theme now changes the color to purple, this color works with white and black text.
There is no way other than applying my light them to get it back. :?
This really needs to move to the qss file.
Also if we want a quick fix then we should change the yellow default color to a color from this site.
