Tools>Customize>Macros in user.cfg
drmacro
Post by drmacro »
@chennes
When the Tools>Customize>Macros is used to define a macro for use in toolbars the following is created in user.cfg:
      <FCParamGroup Name="Macro">
          <FCParamGroup Name="Macros">
            <FCParamGroup Name="Std_Macro_0">
                <FCText Name="Script">Snip.FCMacro</FCText>
                <FCText Name="Menu">Screen Cap</FCText>
                <FCText Name="Tooltip"></FCText>
                <FCText Name="WhatsThis"></FCText>
                <FCText Name="Statustip"></FCText>
                <FCText Name="Pixmap">camera-photo</FCText>
                <FCText Name="Accel"></FCText>
                <FCBool Name="System" Value="0"/>
            </FCParamGroup>
          </FCParamGroup>
If I run Python code to enter the above into the user.cfg and then view it with Tools>Edit parameters it can be seen in the parameters. But, if FreeCAD is shutdown at that point this param group is not saved in user.cfg.
Is there some way to trigger this to be persisted?
chennes
Re: Tools>Customize>Macros in user.cfg
Post by chennes »
Are you using FreeCADGui.Command.createCustomCommand to do it?
Chris Hennes
Pioneer Library System
Roy_043
Post by Roy_043 »
Try:
FreeCAD.saveParameter()
drmacro
Post by drmacro »
Roy_043 wrote: Sun Sep 18, 2022 3:59 pm Try:
I assume this does the same thing the "Save to disk" button does in the Parameters dialog does.
Both that button and this command saves the current state of the params to user.cfg. (i.e. with FC open after issuing this command, I open user.cfg in an editor, the param group is there. If I then close FC, the param group is not in user.cfg.)
One thing I've noted is that after the param group has been added (and before closing FC) the new macro definition does not show up in the Tool>Customize>Macros dialog. But, creating a macro in said dialog will persist the the one created in the dialog overwriting the the one added programmatically.
chennes wrote: Sun Sep 18, 2022 3:50 pm Are you using FreeCADGui.Command.createCustomCommand to do it?
No, I'm attempting to add the macro with a PP.
I originally had the code to write this param group in PP post.FCMacro. I have written code to add the TUX Persistent toolbars and then added code for this param group since it apparently does not get written by the PP apply process. I have since isolated the code into a Python files so I could debug it.
chennes
Post by chennes »
If you want to see how the Addon Manager does it, that code is about here:
https://github.com/FreeCAD/FreeCAD/blob ... ar.py#L232
Chris Hennes
drmacro
Post by drmacro »
chennes wrote: Sun Sep 18, 2022 5:48 pm If you want to see how the Addon Manager does it, that code is about here:
I think I see where this code adds and a macro to a toolbar. Even where it forces the toolbars to reload.
But, I'm not seeing the creation of the actual macro. I'm talking about what this dialog does:
I think that code is adding an existing to this toolbar?
chennes
Post by chennes »
It's really both rolled into one -- it doesn't "create" the macro, in the sense that the actual FCMacro file must already exist, but it creates that section of the CFG file that you quoted above. It's doing that in the call to FreeCADGui.Command.createCustomCommand, which creates the command. The code that's adding that to the toolbar is the next line, toolbar.SetString(command_name, "FreeCAD"), though to make that line work there's a large amount of setup work a priori creating that toolbar (which is basically all the rest of that file does).
Chris Hennes
drmacro
Post by drmacro »
chennes wrote: Sun Sep 18, 2022 7:01 pm It's really both rolled into one -- it doesn't "create" the macro, in the sense that the actual FCMacro file must already exist, but it creates that section of the CFG file that you quoted above. It's doing that in the call to FreeCADGui.Command.createCustomCommand, which creates the command. The code that's adding that to the toolbar is the next line, toolbar.SetString(command_name, "FreeCAD"), though to make that line work there's a large amount of setup work a priori creating that toolbar (which is basically all the rest of that file does).
After looking at that code for a while I see pretty much what is does. I even got FreeCADGui.Command.createCustomCommand to return.
But, the real question is why, even after the param group is written to the .cfg is closing FC throwing it away?
chennes
Post by chennes »
It's similar to what was happening with the toolbars: when FreeCAD exits, it is basically overwriting the config data with the "actual" data, asking the Command Manager for its list of commands and storing that.
Chris Hennes
drmacro
Post by drmacro »
chennes wrote: Sun Sep 18, 2022 7:57 pm It's similar to what was happening with the toolbars: when FreeCAD exits, it is basically overwriting the config data with the "actual" data, asking the Command Manager for its list of commands and storing that.
I'm going to step away from this for a while.
Thanks for all the help.
