@chennes
Side question: How does one specify TabBar or Glass as a depend?
Since they don't have a package.xml file, what is their name?
Trigger UI update after programmatic UI changes
Re: Trigger UI update after programmatic UI changes
You use the name of their git repo: those two are just "Glass" and "TabBar".
I don't know -- I'll have to see if I can replicate it locally, but I have had some problems with threads on Linux not terminating when requested (which is why that error message is there!). I'm not a fan of QtWebEngine, I wish their were a good alternative, but I haven't found one.
@chennes
Sigh, earlier today it worked with depend set to Lattice2 Workbench, I then changed it to TabBar. It simply ignored that.
Now I get this if I try to install the same PP:
Edit: false flag. The cfg file in the PP was bad...not sure how.
11:11:01 Traceback (most recent call last):
11:11:01 File "/home/mac/fc-daily-build-occt77/Mod/AddonManager/AddonManager.py", line 1220, in resolve_dependencies
11:11:01 missing = CommandAddonManager.MissingDependencies(repo, self.item_model.repos)
11:11:01 File "/home/mac/fc-daily-build-occt77/Mod/AddonManager/AddonManager.py", line 1057, in __init__
11:11:01 __import__(py_dep)
11:11:01 File "/usr/lib/python3/dist-packages/shiboken2/files.dir/shibokensupport/__feature__.py", line 142, in _import
11:11:01 return original_import(name, *args, **kwargs)
11:11:01 ValueError: Empty module name
After figuring out the cfg issue, this is still a thing on the Manjaro box...chennes wrote: ↑Sat Aug 27, 2022 2:55 pmI don't know -- I'll have to see if I can replicate it locally, but I have had some problems with threads on Linux not terminating when requested (which is why that error message is there!). I'm not a fan of QtWebEngine, I wish their were a good alternative, but I haven't found one.
- adrianinsaval
isn't the distro and/or machine difference more likely to be the cause rather than installing vs not installing?
Not sure what you are referring to.adrianinsaval wrote: ↑Sun Aug 28, 2022 6:51 pm isn't the distro and/or machine difference more likely to be the cause rather than installing vs not installing?
