Turning Zolko's theme in to a Preference Pack
Zolko
Re: Turning Zolko's theme in to a Preference Pack
Post by Zolko »
chennes wrote: Thu Sep 08, 2022 6:27 pm Is this line failing (e.g. giving "None")?
tv = Gui.getMainWindow().findChild(QtGui.QWidget,'Tree view')
It's probably the line after with addChildWidget and tv being None
mw.addDockWidget(QtCore.Qt.LeftDockWidgetArea,tv)
#0  /lib/x86_64-linux-gnu/libc.so.6(+0x3bd60) [0x7f54fee59d60]
#1  0x7f54fff5b43f in QLayout::addChildWidget(QWidget*) from /lib/x86_64-linux-gnu/libQt5Widgets.so.5+0xf
#2  /lib/x86_64-linux-gnu/libQt5Widgets.so.5(+0x2b471f) [0x7f550008d71f]
chennes
Post by chennes »
Right, in your final distributed script you should make sure tv exists before using it -- I'm just making sure I understand the underlying problem, which is that findChild() isn't giving a valid result when it looks for 'Tree view' in a fresh FreeCAD install.
Chris Hennes
Pioneer Library System
Is there any downside to having the tree view enabled but not shown by default in FreeCAD?
Zolko
Post by Zolko »
adrianinsaval wrote: Sat Sep 10, 2022 1:00 pm Is there any downside to having the tree view enabled but not shown by default in FreeCAD?
I think I've read somewhere that Werner has changed the defaults sometime ago. Werner, could you please confirm and explain this choice ?
wmayer wrote: ping
Zolko wrote: Mon Sep 12, 2022 12:13 pm I think I've read somewhere that Werner has changed the defaults sometime ago. Werner, could you please confirm and explain this choice ?
In FreeCAD we already have the ComboView that includes a tree view and the property view. Having a second and separate tree view does not only look strange but also has a performance issue because all changes in the document structure or selection changes must be handled twice in the two tree instances.
wmayer wrote: Mon Sep 12, 2022 2:05 pm has a performance issue because all changes in the document structure or selection changes must be handled twice in the two tree instances.
even if one is hidden by default?
Zolko
Post by Zolko »
wmayer wrote: Mon Sep 12, 2022 2:05 pm In FreeCAD we already have the ComboView that includes a tree view and the property view.
I understand, but if you use this then the Task UI hides the TreeView, therefore if you want to select something in the tree while being in a task, you're toast. Yes, you can change the tab, but 1) the user needs to know that something important is hidden there and 2) it's so much extra clicks. As for the space on the screen, most people who do 3D CAD have large screens (or several large screens !) anyway.
For the sheer discoverability of FreeCAD (mostly for newcomers) I think that a separate TreeView and PropertyView is more appropriate. Experienced users who need all possible extra performance can later fine-tune their UI. A separate TreeView on the left is also what most (or all ?) other CAD software provide, it's a sort-of industry standard.
Sure. The tree view is part of the Model-View-Controller pattern and it still handles changes made on the model. Only if the tree view doesn't exist it won't handle the changes.
The topic has already been discussed a few times and ideally it should be possible that we don't have the fix layout of the current combo view but allow it the user to split the tab widget(s) to make the tree, property and task view independent dock widgets.
Zolko
Post by Zolko »
wmayer wrote: Mon Sep 12, 2022 3:21 pm Only if the tree view doesn't exist it won't handle the changes.
and if I use a separate Tree View and Property View, then I'll only have 1 tree instance, no ? So no performance hit, is that correct ?
