Turning Zolko's theme in to a Preference Pack
Re: Turning Zolko's theme in to a Preference Pack
Isn't this a better solution ?
For those with a big monitor it's indeed an interesting option but not everybody has a big monitor. For my 23" monitor having a dock window on the left and right side already would require too much space.
What layout would you be missing ? It seems to me that the "Combo View" puts the TreeView above the PropertyView a,d the TaskPanel behind (and I can't un-dock it, therefore the TaskPanel always hides the TreeView):
As said with the planned change for the default mode all three views will be independent dock widgets and can be arranged as the user needs it. For the new combo mode the tree view and property view will be added to a dock widget with a QSplitter and the task view will be added to its own dock widget. Of course, this means the layout is less flexible but also requires less space.
@Zolko @user1234
Here is the implementation of the new dock window handling: https://github.com/wwmayer/FreeCAD/tree/dock_windows
Zolko
Post by Zolko »
wmayer wrote: Fri Sep 16, 2022 8:12 am @Zolko @user1234
Nice ! It seems to work in a general usage (didn't test it extensively though) and looks good in my setup.
Now, when applying the ZolkoPack2 (the new one attached, the old one will crash FreeCAD because the Combo View is now called Tasks) from a vrigin FreeCAD (by removing the folder FreeCAD in ~/.config), then I nearly get the correct layout, except that the Task window is not shown. When I apply the post.FCMacro (included in the pack) from the Python console then it DOES show.
If I apply the ZolkoPack2 on a config-less startup and then type manually into the Python console:
from PySide import QtGui, QtCore
Gui.getMainWindow().findChild(QtGui.QWidget,'Tasks').show()
then the Task panel is shown. I tried various orders for the panels but it doesn't change anything. I would guess that this is somehow due to the new name "Combo View" => "Tasks"
OS: Debian GNU/Linux 11 (bullseye) (KDE/plasma)
Version: 0.21.30341 (Git)
Build type: Compiled
Hash: 74ffd403643405ffd7e44e26d9b62673ffa7956a
Python 3.9.2, Qt 5.15.2, Coin 4.0.0, Vtk 7.1.1, OCC 7.6.2
  * A2plus 0.4.56a
  * CurvedShapes 1.0.3
  * fcgear 1.0.0
  * sheetmetal 0.2.50
  * TabBar
  * Render 2022.2.0
  * Curves 0.5.1
  * fasteners 0.4.4
  * Assembly4_GitHub 0.12.4
ZolkoPack2.zip
(1.76 KiB) Downloaded 64 times
Weird. Maybe a problem with the Qt version. Actually Qt doesn't know the relation of the Task view to the old Combo View and thus should handle it as a new dock window.
Also strange. For me the Task view was visible by default.
Zolko
Post by Zolko »
wmayer wrote: Fri Sep 16, 2022 1:34 pm For me the Task view was visible by default.
on config-less startup no panel is shown here
Zolko
Post by Zolko »
wmayer wrote: Fri Sep 16, 2022 1:34 pm Maybe a problem with the Qt version
But only for the Task panel ? Do you have a proposal I could test ?
No, not really.
Zolko
Post by Zolko »
I tried to play with some booleans in MainWindow.cpp and Workbench.cpp:
DockWindowItems* StdWorkbench::setupDockWindows() const
    auto root = new DockWindowItems();
    root->addDockWidget("Std_ToolBox", Qt::RightDockWidgetArea, false, false);
    //root->addDockWidget("Std_HelpView", Qt::RightDockWidgetArea, true, false);
    root->addDockWidget("Std_TreeView", Qt::LeftDockWidgetArea, true, false);
    root->addDockWidget("Std_PropertyView", Qt::LeftDockWidgetArea, true, false);
and while it did do some changes (from left to right of the window for example) it refuses to show the panels - any panel - at config-less or completely virgin startup.
Also, the Task panel shows as it should when running the post.FCMacro directly from FreeCAD, but refuses to show when applying the SAME macro with the PreferencePack. Even worse, if the Task panel is already visible, it disappears when the PreferencePack is applied.
Zolko
Post by Zolko »
Zolko wrote: Fri Sep 16, 2022 8:57 pm the Task panel shows as it should when running the post.FCMacro directly from FreeCAD, but refuses to show when applying the SAME macro with the PreferencePack
ha, gotcha: the PreferencePack isn't aware of the new dock window called Std_TaskView, that's why it doesn't show it. I edited the pack .cfg file by hand to add that dock window and now the window layout shows as it should.
Next step : the toolbars.
(although I still think that such a macro included in a preference pack is dangerous)
Jolbas wrote: Sun Aug 28, 2022 6:06 am Shouldn't those scripts be considered a security risk ? It's not obvious to me that a preference pack contains executables.
ZolkoPack3.zip
(1.63 KiB) Downloaded 60 times
drmacro
Post by drmacro »
The macro/s in the PP in github that I made already does the toolbars.
