Turning Zolko's theme in to a Preference Pack
Re: Turning Zolko's theme in to a Preference Pack
for what it's worth, I attach my config folder (in Linux, in ~/.config/FreeCAD (and my real start-up workbench is Part and not PartDesign, but that should be easy to fix))Kunda1 wrote: ↑Mon Aug 15, 2022 1:10 pm Anyone interested in helping make this possible?
Ref: Preference Packs
- FreeCAD.zip
- (9.46 KiB) Downloaded 87 times
@Zolko, thanks! Since it's your theme and you should have some attribution, I propose you give it a name and create repo for it. Then we can start pulling it apart in a collaborative way.
Re: start workbench option is a user config parameter that easily customizable, so yea..no worries
<FCParamGroup Name="General">
<FCText Name="AutoloadModule">PartWorkbench</FCText>
How does one get the tabs down the left side?
Wouldn't it be a good starting place to use the preference pack "Save as"?
Just curious...
Just curious...
Looks like this theme depends on triplus's TabBar addon
<FCParamGroup Name="TabBar">
<FCText Name="Orientation">West</FCText>
<FCText Name="Style">Text</FCText>
<FCText Name="Enabled">Assembly4Workbench,WeldingWorkbench,PartWorkbench,PartDesignWorkbench,CurvedShapesWB,CurvesWorkbench,DraftWorkbench,TechDrawWorkbench</FCText>
<FCText Name="Partially"/>
<FCText Name="Unchecked">A2plusWorkbench,ArchWorkbench,DrawingWorkbench,FastenersWorkbench,FemWorkbench,GearWorkbench,ImageWorkbench,InspectionWorkbench,MeshWorkbench,NoneWorkbench,OpenSCADWorkbench,PathWorkbench,PointsWorkbench,RaytracingWorkbench,RenderWorkbench,ReverseEngineeringWorkbench,RobotWorkbench,SMWorkbench,SketcherWorkbench,SpreadsheetWorkbench,StartWorkbench,SurfaceWorkbench,TestWorkbench,WebWorkbench</FCText>
<FCText Name="Position">Assembly4Workbench,WeldingWorkbench,PartWorkbench,PartDesignWorkbench,A2plusWorkbench,ArchWorkbench,CurvedShapesWB,CurvesWorkbench,DraftWorkbench,DrawingWorkbench,FastenersWorkbench,FemWorkbench,GearWorkbench,ImageWorkbench,InspectionWorkbench,MeshWorkbench,NoneWorkbench,OpenSCADWorkbench,PathWorkbench,PointsWorkbench,RaytracingWorkbench,RenderWorkbench,ReverseEngineeringWorkbench,RobotWorkbench,SMWorkbench,SketcherWorkbench,SpreadsheetWorkbench,StartWorkbench,SurfaceWorkbench,TechDrawWorkbench,TestWorkbench,WebWorkbench</FCText>
</FCParamGroup>
yes, and that one should be part of a standard FreeCAD package
Indeed drmacro!
@Zolko , would you please do this? (See Preference_Packs#Creating_a_new_pack)
Also I've started a gist for the package.xml file following the Package_Metadata docs.
see attached, remove the .txt extension, and place in :
~/.local/share/FreeCAD/SavedPreferencePacks/ZolkoPack/
- ZolkoPack.cfg.txt
- (4.04 KiB) Downloaded 84 times
When I us the zolko files it does not find the icon for offset 3D curves.
