Can we rename the page ?
The original page on PP is aptly named Preference Packs
so...perhaps we should call this one Private Preference Packs or should it just be added as a subsection in Preference Packs ?
Edit: I think it should be merged as a subsection of Preference Packs
Turning Zolko's theme in to a Preference Pack
Re: Turning Zolko's theme in to a Preference Pack
I had some time to refine this setup, and now, starting from a virgin install (no FreeCAD config file in ~/.config/FreeCAD, but still the FreeCAD Mod directory in ~/.local/share/FreeCAD where the preference packs are saved), applying the #4 version of the pack attached) makes for a largely nice and usable window. It only works with that new dock window handling, and crashes hard with any other version.wmayer wrote: ↑Fri Sep 16, 2022 8:12 am Here is the implementation of the new dock window handling: https://github.com/wwmayer/FreeCAD/tree/dock_windows
Unfortunately, I fail to make it switch to the PartDesign workbench automatically – with Gui.activateWorkbench('PartDesignWorkbench') – because that screws up completely the window and toolbars layout. I tried to put in a sleep() or similar, but no luck. But when switching manually to the Part Design workbench, the user gets a nice and comfy window, which I think would be an improvement over the current empty startup layout.
A also added some nice goodies like VBO and refine=True as defaults
This could be combined as an option in the start-up wizzard to provide newcommers with a friendlier fresh install (I have no opinion about the default background color).
BUT: for any of this to have a meaning, that alternative dock window handling (which makes the separate tree-view and property view default) needs to be merged. I don't know whether there is a consensus on that.
ALSO: this uses triplus tab toolbar addon, which I think should be merged into FreeCAD core: this allows fast 1-click switching between often used workenches. I didn't have yet time to arrange and remove items from that toolbar
OS: Debian GNU/Linux 11 (bullseye) (KDE/plasma)
Version: 0.21.30341 (Git)
Build type: Compiled
Hash: 74ffd403643405ffd7e44e26d9b62673ffa7956a
Python 3.9.2, Qt 5.15.2, Coin 4.0.0, Vtk 7.1.1, OCC 7.6.2
* A2plus 0.4.56a
* CurvedShapes 1.0.3
* fcgear 1.0.0
* sheetmetal 0.2.50
* TabBar
* Render 2022.2.0
* Curves 0.5.1
* fasteners 0.4.4
* Assembly4_GitHub 0.12.4
* QuickMeasure 2022.10.28
- ZozoPack4.zip
- (1.87 KiB) Downloaded 61 times
- adrianinsaval
what's the point of having the selector toolbar and the regular workbench selector? Personally I have long ago ditched the built-in selector in favor of triplus' addon.
in the selector I have *ALL* available workbenches, in the workbench toolbar only those I use *VERY* often : I also use them in text so the tabs are large and clicking them is easy and fast.adrianinsaval wrote: ↑Thu Nov 10, 2022 12:55 pm what's the point of having the selector toolbar and the regular workbench selector ?
- adrianinsaval
Hmm, perhaps we are not using the same addon? selector toolbar addon has a dropdown menu that by default has all WB too (I have manually disabled those I know I'm never going to use). I know triplus had made a similar addon before that was superseded by selector toolbar, maybe you are using that one.
I have the same setup @Zolko does -- I believe it's just Triplus's normal toolbar addon, configured via its preferences to only show five of my most-used workbenches, but I have all workbenches showing in the built-in selector.
Yes it is. I added the TabbBar section of the user.cfg file to the preference pack, and now it gives the following setup when staring with a virgin FreeCAD (no config directory, but the Mod directory is there with the PreferencePacks):
Virging startup:
after applying ZolkoPack5:
I think that the TabBar should be included by default in FreeCAD, it is so much easier to use FreeCAD's workbenches with that. And the workbench concept is central to FreeCAD. Also, I think that the new docking code should be merged, which only proposes the "Combo View" (combined Tree+Property panel with a separate Task panel) and the separate option (Tree, Task and Property panels separated and stackable as the user wishes) which becomes default.
And then something similar as this PreferencePack should be included in the next startup wizzard. Any opinions ? Should I make tickets for these in the GH issues ?
- ZolkoPack5.zip
- (2.29 KiB) Downloaded 75 times
