Turning Zolko's theme in to a Preference Pack
drmacro
Re: Turning Zolko's theme in to a Preference Pack
Post by drmacro »
What is the ms/fps display in the lower left of the 3D view?
And, more importantly...how does one get rid of it?
EDIT: Found it...
user1234
Post by user1234 »
drmacro wrote: Mon Aug 15, 2022 2:48 pm And, more importantly...how does one get rid of it?
ez
Greetings
user1234
obelisk79
Post by obelisk79 »
Zolko wrote: Mon Aug 15, 2022 1:40 pm
Kunda1 wrote: Mon Aug 15, 2022 1:36 pm Looks like this theme depends on triplus's TabBar addon
yes, and that one should be part of a standard FreeCAD package
Not everyone likes the tab-bar addon, I rather dislike it. If added to a standard install of freecad it better be optional.
drmacro
Post by drmacro »
obelisk79 wrote: Mon Aug 15, 2022 3:17 pm
I find it somewhat more palatable as icons opposed to tabs. Either way, I don't expect a new user is going to grok the idea. Once you know what the icons or labels mean then it may be marginally better the a drop down box.
Jee-Bee
Post by Jee-Bee »
obelisk79 wrote: Mon Aug 15, 2022 3:17 pm Not everyone likes the tab-bar addon, I rather dislike it. If added to a standard install of freecad it better be optional.
Be able to switch it off is also optional right...
obelisk79
Post by obelisk79 »
Jee-Bee wrote: Mon Aug 15, 2022 7:11 pm
yes
drmacro
Post by drmacro »
I am continuing to use/explore this configuration.
One note is that the specific Assembly 4 tweaks may not be desirable in a default pack. And, it took me some digging to get them gone...
There are other things that I think would help new users that are turned off/on. While the navicube is there, I think the axis cross should be available, it is just a more obvious indication of the world coordinate system and where the user orients.
I also think the esc to exit Sketcher should be off by default. For new users it is frustrating to hit esc to exit a command, but exit sketcher instead.
I also don't want the Blender mouse mode as default. It should be CAD.
Maybe a separate pack for commonly selected mouse modes...
drmacro, do you have the config files available on github somewhere? Lets put this thing together :)
I have the package.xml file here
Zolko
Post by Zolko »
drmacro wrote: Mon Aug 15, 2022 1:35 pm Wouldn't it be a good starting place to use the preference pack "Save as"?
PreferencePacks don't save window layout, toolbar layout, default start-up workbench ... so not really adapted for the task.
drmacro
Post by drmacro »
Zolko wrote: Tue Aug 16, 2022 2:03 pm
Hmm...that might explain it the stuff I'm seeing. I actually used the config you posted the other day...
I actually didn't use the saved pack you posted later.
