More ideas for minor UI tweaks.
MisterMaker
Post by MisterMaker »
First one:
Turning the currently workbench toolbar that is in Linkstage in a overlay and turn it into a dock, just like we have on the mac and on some Linux systems. Probably not so hard to do for @realthunder :)
docks small.png (770.97 KiB) Viewed 1309 times
Second grouping the Property view and the selection view into pull down menu's instead of tabs.
And/or using side tabs that let you open these panels on the go, this as an alternative too the autohide function in Linkstage.
Example from Ms Code.
Re: More ideas for minor UI tweaks.
I like the idea of an overlayed toolbar, regarding data and view properties grouping i actually prefer the tabs, much easier to switch from one to the other. A sidebar to control active panels is also a good idea IMO.
MisterMaker
Can probably do the sidebar with just macro buttons, I'll try tomorrow.
MisterMaker
Made the macro's, wasn't that hard with this macro:
https://wiki.freecadweb.org/Macro_Toggl ... Visibility
Now I need 9 icons. :shock:
MisterMaker
Got it too work with custom icons, although no fancy ones just simple letters.
Demonstration here:
https://twitter.com/MisterMakerNL_/stat ... 0869583872
Macro's below with icons.
Macro.zip
(71.18 KiB) Downloaded 45 times
