In the Combo View, under the Model tab, would it be possible to have the right edge of the Description column attached to the right edge of the pane :
It would be cool to see the whole Description field by expanding the combo view
Combo View - small improvement
- LordMadJack
- Screen1.png (50 KiB) Viewed 1248 times
- Screen2.png (46.4 KiB) Viewed 1248 times
Re: Combo View - small improvement
The current behavior is on purpose : https://github.com/FreeCAD/FreeCAD/blob ... e.cpp#L529
This is so that the 'Description' keeps it's width when you unfold the document tree, that "pushes" the Description column to the right.
Would you like this to be an option where yo can choose between the 2 behaviors (current and wanted) ?
- LordMadJack
Thanks !
Not so much details on my previous post.
If/when the PR is merged, you have to create a boolean parameter in "Preferences/TreeView" named "TreeViewStretchDescription" with value set to "true" to get the behavior you want (Parameter editor).
This is a minimal implementation. It can later be made a preference, and eventually above behavior be made the default one.
Merged as rev 28703.
Note to myself : documentation
Documented in Fine-tuning
