NaviCube Anti-Aliasing (lack therof)
asegura
Re: NaviCube Anti-Aliasing (lack therof)
Post by asegura »
OK, a similar change in the texture that holds the navicube "arrows" also makes them smother.
I don't know how to proceed. A full pull-request for just 2 lines changed and 2 lines added?
The change is to have this:
	texture->generateMipMaps();
	texture->setMinificationFilter(QOpenGLTexture::LinearMipMapLinear); // new
instead of this:
	texture->setMinificationFilter(QOpenGLTexture::Linear); // old
in src/Gui/NaviCube.cpp :
* around line 531 (end of createButtonTex())
* and line 425 (end of createCubeFaceTex())
There is another texture in createMenuTex() line 604, but I see almost no difference here.
chennes
Post by chennes »
@uwestoehr does this warrant inclusion in 0.20? Or do you want to hold for 0.21? (@asegura we are in a feature freeze right now so the answer to you question depends on what the release manager, Uwe, thinks is best)
Chris Hennes
Pioneer Library System
asegura
Post by asegura »
FYI, this is based on master and improves on this recent commit https://github.com/FreeCAD/FreeCAD/comm ... 2c4e9f3ed5. Best noticeable in the text on the cube's faces when rotating.
Now I've seen that the generateMipMaps() call is not necessary, it seems mipmaps are generated automatically by default. So it is only 2 lines changed:
--- "a/I:\\src\\_Ext\\FreeCAD\\src\\Gui\\NaviCube.cpp"
+++ "b/I:\\src\\_Ext\\FreeCAD\\src\\Gui\\NaviCube-orig.cpp"
@@ -422,7 +422,7 @@ GLuint NaviCubeImplementation::createCubeFaceTex(QtGLWidget* gl, float gap, cons
 	Q_UNUSED(gl);
 	QOpenGLTexture* texture = new QOpenGLTexture(image.mirrored());
 	m_glTextures.push_back(texture);
-	texture->setMinificationFilter(QOpenGLTexture::LinearMipMapLinear);
+	texture->setMinificationFilter(QOpenGLTexture::Linear);
 	texture->setMagnificationFilter(QOpenGLTexture::Linear);
 	return texture->textureId();
@@ -527,7 +527,7 @@ GLuint NaviCubeImplementation::createButtonTex(QtGLWidget* gl, int button) {
 	Q_UNUSED(gl);
In short, when rendering textures at a smaller resolution (minification), best result is with LinearMipmapLinear minification filtering.
uwestoehr
Post by uwestoehr »
chennes wrote: Fri Jun 03, 2022 6:07 pm @uwestoehr does this warrant inclusion in 0.20?
Absolutely yes. severl people tried their best few days ago and we could commit some improvements but it looks on some screens still clumsy.
So the patch to make is smooth is very welcome!
@chennes, can you please take over an manage the commit? (I am still busy with packaging issues).
uwestoehr
Post by uwestoehr »
asegura wrote: Fri Jun 03, 2022 5:59 pm I don't know how to proceed.
We work with pull requests, no matter how small the change is.
I tested your proposal and just using lineal does not change anything visibly for me, MipMap, however does. Therefore I made now a PR:
https://github.com/FreeCAD/FreeCAD/pull/6962
nice improvement!
