[Sketcher] Clearer icons for : Polyline, toggle construction, toggle constraints, toggle active constraints, ext geo
paddle
Re: [Sketcher] Clearer icons for : Polyline, toggle construction, toggle constraints, toggle active constraints, ext geo
Post by paddle »
chrisb wrote: Thu Sep 15, 2022 11:50 am
paddle wrote: Thu Sep 15, 2022 8:32 am toggle constrain icons.png
I like the idea of reusing one of the dimensional icons and the angle symbol is good. As the most frequently used dimensional constraints are vertical and horizontal distance, I would appreciate it even more, if it was based on the horizontal distance icon.
I tried with distance but it didn't look good. I think with horizontal distance it will look similarly bad.
Maybe distance + horizontal distance together. But I'm not sure if it will look better than with angle.
my take on toggle reference constraints:
Sin título.png (24.67 KiB) Viewed 4717 times
Sketcher_ToggleConstraint.svg
(2.32 KiB) Downloaded 88 times
we can play with the separator color, angle of rotation or use the dimension icon as base instead of rotated horz. distance
MisterMaker wrote: Mon Sep 19, 2022 9:24 am Mine is here I re-used dimension icon.
I'm not sure about the meaning of the "no parking" overlay. And it may be a bit too crowded to work with small size. I would like to see adrianinsaval's icon just turned horizontally :mrgreen: .
MisterMaker
Post by MisterMaker »
@chrisb It's called a toggle but what you basically do is disable or enable the constrain. And so I added a disable icon on top of it. And yes you also press it to enable it, but there are not enough pixels for both.
Haavard
Post by Haavard »
A couple of tries using the default dimension icons:
MisterMaker wrote: Mon Sep 19, 2022 6:02 pm @chrisb It's called a toggle but what you basically do is disable or enable the constrain. And so I added a disable icon on top of it. And yes you also press it to enable it, but there are not enough pixels for both.
Aah, I understand the "disable" now. I could argue now that I didn't understand it immediately, but that's perhaps just me. But independent from that I would prefer less stuff on the icon.
Adrians proposal made horizontal.
Sketcher_ToggleConstraintHorizontal.svg
(4.52 KiB) Downloaded 85 times
paddle
Post by paddle »
Haavard wrote: Mon Sep 19, 2022 9:30 pm A couple of tries using the default dimension icons:
I like the third.
chrisb wrote: Mon Sep 19, 2022 9:44 pm Aah, I understand the "disable" now. I could argue now that I didn't understand it immediately, but that's perhaps just me. But independent from that I would prefer less stuff on the icon.
Same here I didn't get it directly and think it's too detailed.
So what are we doing now? We have several good options so what now?
What about polyline icon ?
paddle wrote: Tue Sep 20, 2022 11:09 am So what are we doing now? We have several good options so what now?
Should we make one of these famous polls? (3 participants guaranteed :roll: )
I dig the archives. There were some proposals showing that Polyline can do more than straight lines.
