Dear FreeCAD developers,
I recently started to use FreeCAD and while working with the TechDraw workbench I felt that drag and drop from the Model treeview could be enabled to the TechDraw work area and triggering the "Insert a view" action would be quite natural. What do you think about this improvement? I have some experience with Qt/C++ so if the idea got some positive feedback I could came up with a PR.
Drag and drop in the TechDraw workbench
- Screenshot_20220125_211021.png (81.42 KiB) Viewed 2004 times
Re: Drag and drop in the TechDraw workbench
Drag and drop was enabled before 0.20, and was removed because it didn't work properly (similar in Path workbench) and could even destroy models completely.
If you can fix it: go for it.
It probably was disabled before 0.19 became stable.
Well I built the actual git master and found a very frustrating behavior:
If I click (with a single left click) on anything on the model tree it get activated in the main windows immediately (making the drag and drop impossible).
Could it be intentional?
I have no idea. I rather know it from the Path workbench, where we indeed could destroy whole files by drag and drop. I then tried it once with TechDraw, and we saw that the same issue existed there. Now it seems prohibited.
I have no idea where or when or what has been done or if not a new Qt library improved things all by itself.
