Icon suggestion for CarbonCopy
JoeKundlak
Post by JoeKundlak »
I have a suggestion for the SVG for CarbonCopy. Could it be adjusted to have a solid line for the shape in the background?
I get the intent with the quasi-dotted line, but at icon size on the wiki the blue shape looks fuzzy IMO.
On the contrary the ToggleConstruction SVG is more crisp as its blue dotted shape is more uniform in its color combination (blue and darker blue).
To not have both symbols look the same the CarbonCopy could be say red and black or red and grey with the foreground shape, while the ToggleConstruction could retain the red/blue combination.
Example below, you can also see a "live" example on the Wiki on my user page.
CarbonCopy suggestion.png (39.14 KiB) Viewed 4221 times
CarbonCopy suggestion_small.png (8.7 KiB) Viewed 4221 times
Attached also the SVG.
Sketcher_CarbonCopy_Joe.svg
(11.14 KiB) Downloaded 83 times
Joe
translating into SK: https://wiki.freecadweb.org
bitacovir
Re: Icon suggestion for CarbonCopy
Post by bitacovir »
JoeKundlak wrote: Fri Nov 26, 2021 12:03 pm I have a suggestion for the SVG for CarbonCopy. Could it be adjusted to have a solid line for the shape in the background?
Hi. I like it.
Is it following the FreeCAD artwork guidelines?
http://wiki.freecadweb.org/Artwork_Guidelines
Lets see if there is consensus to change this icon with a PR.
::bitacovir::
My personal web site
My GitHub repository
Mini Airflow Tunnel Project
why 3 sketches in the icon though? shouldn't it just be one white/black one white/red? Otherwise I agree.
JoeKundlak
bitacovir wrote: Fri Nov 26, 2021 12:48 pm Hi. I like it.
Will check the Guidelines and report back!
adrianinsaval wrote: Fri Nov 26, 2021 1:19 pm why 3 sketches in the icon though? shouldn't it just be one white/black one white/red? Otherwise I agree.
Thought it could confuse someone if just two shapes were present as it is a bit similar to the aforementioned ToggleConstruction icon. But if the consensus will be to have just one copy, sure, why not? Can do an image with just one, will post it later today...
Joe
JoeKundlak
Icon with just one copy in the background, 2 versions (spacing different).
CarbonCopy suggestion 2.png (14.46 KiB) Viewed 4074 times
CarbonCopy suggestion 2 small.png (3.22 KiB) Viewed 4074 times
CarbonCopy suggestion 3.png (16.22 KiB) Viewed 4074 times
CarbonCopy suggestion 3 small.png (3.62 KiB) Viewed 4074 times
Joe
JoeKundlak wrote: Fri Nov 26, 2021 1:40 pm Thought it could confuse someone if just two shapes were present as it is a bit similar to the aforementioned ToggleConstruction icon. But if the consensus will be to have just one copy, sure, why not? Can do an image with just one, will post it later today...
IMO the current red and blue icon is easier to confuse with it.
Just brainstorming here:if the white one is in front I think it will be easier to distinguish, does it make sense putting that in front?
hmk
Post by hmk »
JoeKundlak wrote: Fri Nov 26, 2021 1:40 pm a bit similar to the aforementioned ToggleConstruction icon.
Thanks for the initiative. This is exactly the issue I have with the current icons. All your suggested icons are a major improvement, I personally prefer the 3-shape versions.
JoeKundlak
adrianinsaval wrote: Fri Nov 26, 2021 5:01 pm Just brainstorming here:if the white one is in front I think it will be easier to distinguish, does it make sense putting that in front?
You mean like this?
CarbonCopy suggestion 4.png (22.42 KiB) Viewed 3787 times
hmk wrote: Sun Nov 28, 2021 7:27 pm Thanks for the initiative. This is exactly the issue I have with the current icons. All your suggested icons are a major improvement, I personally prefer the 3-shape versions.
I cannot claim I invented the looks, I just iterated on JoshuaCall's icon (ToggleConstruction.SVG).
I too am more fond of the 3-shape design as it is more distinguishable to the many 2-icon ones currently present.
Joe
