Help importing realthunder's FreeCAD branch into KDevelop IDE
Technicus
Post by Technicus »
Hey there,
I am trying to import realthunder's FreeCAD branch into KDevelop IDE as a project by opening the CMakeLists.txt file.
It reports:
-- Could NOT find utf8cpp (missing: utf8cpp_INCLUDE_DIR)
-- VTK components: not found or used
CMake Error at /usr/share/cmake-3.21/Modules/FindPackageHandleStandardArgs.cmake:230 (message):
  Could NOT find OpenVR (missing: OpenVR_INCLUDE_DIR)
Call Stack (most recent call first):
  /usr/share/cmake-3.21/Modules/FindPackageHandleStandardArgs.cmake:594 (_FPHSA_FAILURE_MESSAGE)
  /usr/lib64/cmake/vtk/FindOpenVR.cmake:45 (find_package_handle_standard_args)
  /usr/lib64/cmake/vtk/VTK-vtk-module-find-packages.cmake:256 (find_package)
  /usr/lib64/cmake/vtk/vtk-config.cmake:131 (include)
  cMake/FreeCAD_Helpers/SetupSalomeSMESH.cmake:45 (find_package)
  CMakeLists.txt:59 (SetupSalomeSMESH)
I am not sure what dependency I am missing or what needs to be changed.
To check that everything is setup properly, I also did the same with the main FreeCAD source code, and it has no error.
The system I am on is the Arch Linux derivative Garuda.
If anyone has suggestions, please share them with me.
M4x
Re: Help importing realthunder's FreeCAD branch into KDevelop IDE
Post by M4x »
Probably realthunders GitHub repo would be a better place looking for help.
realthunder
Post by realthunder »
If your setup works fine for the current upstream, please wait for a few days. I am currenting doing a merge with the upstream. There's quite a few changes in cmake configurations there. Once the merge is done, maybe your setup will just work.
