HiDPI and drag thresholds
regularfry
Post by regularfry »
Hi folks,
Just wanted to check that I've not missed something here.
I'm on a 3:1 HiDPI display. What I've observed is that I have a far harder time selecting elements in the Sketcher than I see people have in YouTube tutorials. I click and click and click and things just don't get selected. What I believe is happening is that I'm incapable of clicking without subtly moving the mouse between mouse-down and mouse-up when I select an element, and that means my action registers as a drag, not as a click. The net result is that the element I'm trying to select remains unselected, so I have to try again. Several times, usually. Because I'm on a high-ratio display, I often can't visually see the mouse motion that I think is registering, but the behaviour is the same when I can see some movement.
I've dug a little into the code, and I can see that Gesture and MayaGesture both call QApplication::startDragDistance() (https://github.com/FreeCAD/FreeCAD/blob ... le.cpp#L92) but the other interaction styles don't. From that, my assumption would be that those two orbit styles would work better, and subjectively that does seem to be the case. If I switch to MayaGesture, selecting Sketcher elements does feel less frustrating, but I could easily be placebo'ing myself.
Now, I can't see any global preferences for drag thresholds anywhere. It might be that I've just not found them. So, two questions: first, am I right in my assumption that if a selected orbit style does not use QApplication::startDragDistance(), then the implicit drag threshold is zero, and any mouse movement bigger than a pixel triggers a drag? And second, if that is the case, is there a change that can be made globally to introduce a drag threshold configuration?
Re: HiDPI and drag thresholds
No problems here on a Retina 3072x1920 display.
OS: macOS 10.16
Version: 0.20.25429 (Git)
Hash: acce57a25d82b0408fa07b9452ed31c8a06c7a1b
Python version: 3.9.6
Qt version: 5.12.9
OCC version: 7.5.2
Locale: C/Default (C)
(Not sure if this is the right forum.)
regularfry
Which input style do you use, and what pointing device?
Oh, should probably mention: I'm on Windows 10.
regularfry wrote: Sun Aug 22, 2021 12:10 pm Which input style do you use, and what pointing device?
Input device: touch pad; Mouse model: Gesture.
You should show your full FreeCAD infos.
regularfry
Version: 0.19.24291 (Git)
Branch: releases/FreeCAD-0-19
Python version: 3.8.6+
Qt version: 5.15.2
Coin version: 4.0.1
OCC version: 7.5.0
regularfry
chrisb wrote: Sun Aug 22, 2021 12:21 pm
Right, that makes sense then: Gesture is one that calls startDragDistance. If you try a mouse, and pick (for instance) Blender style, do you notice any difference?
regularfry wrote: Sun Aug 22, 2021 1:46 pm If you try a mouse, and pick (for instance) Blender style, do you notice any difference?
No difference, it is as fast as before.
regularfry
Interesting choice of words: my problem isn't speed, it's reliability.
I clearly need to dig into this a little more to prove out what I'm seeing, but it's absolutely consistent with the fact that MayaGestureNavigationStyle.cpp is processing mouseMoveThreshold and BlenderNavigationStyle.cpp has no equivalent. That implies there's zero drag threshold on any of the navigation styles which don't handle it explicitly, so less than perfect hardware (or less than perfect fine motor control, for that matter) is likely to be problematic.
chennes
Post by chennes »
That's certainly how the code reads to me: the MayaGestureNavigation, for example, has a huge amount of code that works to separate out the various possible mouse events, and to re-synthesize clicks if it accidentally ate them. I'd say that this problem is probably fixable, but it won't be trivial to do, and is going to require significant testing.
Chris Hennes
Pioneer Library System
