[Solved] Is there any point of the progress bar?
Started FreeCAD as any normal user would. From Startpage created new Document and "POW!" 100% progress bar. To myself, so what. To a new user, I would suspect Panic. As discussed in https://forum.freecadweb.org/viewtopic.php?f=34&t=57718 nobody knows why. So lets remove it. Simple. I can't see a benefit of the progress bar nowadays.
Re: Is there any point of the progress bar? Lets remove it.
I disagree that the progress bar is obsolete. When working with large and complex models it definitely makes sense.
Fair point for old computers. Users that I promote the use of FreeCAD to come back to me with "FreeCAD is too buggy and consumes 100% of my resources" as they naturally create a new document from the Startpage. Of course this not true, but the 100% progress bar says otherwise. I'll file a bug.
I'm very happy about the progress bar on a regular basis. Especially when I'm filling up gigs of RAM
Regards / Viele Grüße
Max
Max
I agree.turn211 wrote: ↑Mon Jun 07, 2021 4:01 am Started FreeCAD as any normal user would. From Startpage created new Document and "POW!" 100% progress bar. To myself, so what. To a new user, I would suspect Panic. As discussed in https://forum.freecadweb.org/viewtopic.php?f=34&t=57718 nobody knows why. So lets remove it. Simple. I can't see a benefit of the progress bar nowadays.
The whole status bar is a really bad waste of screen real-estate. I personally disable it.
- Tooltips appear when you hover over tools
- Controls is set-and-forget
- Scale of viewport is nice, but it doesn't give you any actual, meaningful information
It definitely does not need 40px in height and full width of the screen.
I agree with your points. Problems I see with both our ideas are:Petrikas wrote: ↑Thu Jun 10, 2021 8:50 am I agree.
The whole status bar is a really bad waste of screen real-estate. I personally disable it.I'd love the progress bar to be auto-hide, so it only appears when on the change of percentage (as opposed to showing 0% or 100% all of the time)
- Too many FreeCAD users have old under powered computers, so they like to see something as their computers are chugging away
- Getting rid of status bar is great for Mechanical modelling but not for Architecture as we use the Navigator and BIM widgets nonstop(which are located in the status bar), but in a moveable Toolbar they could be docked somewhere else (i.e. right lower left)
Also, the ability to hide tabs for documents would be nice, as they are available in the Windows menu and take up a lot of real estate. Most monitors are 16x9 aspect, so we need all the vertical we can get.
Without filter: this is really the dumbest i heard in the forum here. If a mod ban me for that, i am fine.
Yep, that's why I mentioned appearing on a percentage change. Similar to what Fusion360 does. The bar is not visible until it's actually moving. Actual auto-hiding might be annoying.
Hmm, what are operator buttons doing in the "status bar"?Architecture as we use the Navigator and BIM widgets
Thanks! You seem like the smartest person on this Forum, so you fixing it shouldn't be a problem https://forum.freecadweb.org/viewtopic.php?f=34&t=57718
Your Vertical UI solution is very enjoyable to use. Great job! Yes, all Widgets in the Status bar should be moveable. By using a solution like https://forum.freecadweb.org/viewtopic. ... 1&start=50 maybe one could package a Modelling Layout, a Architecture Layout, etc. This way, one camp wouldn't need the fluff of the other. Of course widgets would need to be moveable, dockable etc.Petrikas wrote: ↑Thu Jun 10, 2021 5:29 pmYep, that's why I mentioned appearing on a percentage change. Similar to what Fusion360 does. The bar is not visible until it's actually moving. Actual auto-hiding might be annoying.
