OK.. thanks for that clarification @adrianinsaval! Though I'm still not clear, is restart still needed to view QSS changes made on the fly (without having to restart FC)?adrianinsaval wrote: ↑Mon Oct 03, 2022 5:37 pm werner was probably editing the stylesheet in FreeCAD's source code repo so he does need to rebuild or manually copy the edited stylesheet to get it in his build. For external stylesheets rebuilding FreeCAD is not required at all.
[SOLVED] QPalette::Link for Constraint Formulas in Property Editor (NOTE: restart required)
Re: [SOLVED] QPalette::Link for Constraint Formulas in Property Editor (NOTE: restart required)
I would expect that editing a stylesheet would require a restart for it to be picked up by FreeCAD, same as with workbenches, but I have not tested. But applying a stylesheet shouldn't require restart.
