New overlay mode (Now ready for testing)
Edit: please download my pre-build image for testing.
I didn't realize that there are quite a few threads about this overlay mode until I have finished implement my own and decide to announce it. My overlay mode is inspired from triplus' Glass module, but apparent the idea's been around before it. Anyway, here is a brief demo of my version.
Global shortcut F4 can be used to toggle the overlay mode for all docked windows. When activated, the docked windows will become transparent. mouse over will temporarily deactivate overlay mode.
CTRL+F4 toggles auto hide mode, where all docked windows are hidden by default. Mouse over the edge of the main window will bring up the hidden window. This means the space occupied by the dockables are actually freed up for 3D view, unlike the normal overlay mode. For non-3D views, auto hide mode is implicit for all overlay docked windows.
SHIFT+F4 toggles the transparent mode. The difference between this and normal overlay mode is that it stays transparent (for most of the widgets) even under mouse. It certainly looks cooler, but this mode is also likely to have glitches here and there when editing.
Auto hide mode and transparent mode can be toggled independently with each other. Further customization can be done through external stylesheet, with parameter path BaseApp/Preferences/MainWindow, and string keys OverlayOnStyleSheet (used in normal overlay mode), OverlayOffStyleSheet (used when turning off overlay), OverlayActiveStyleSheet (used in transparent mode). Click the links for the default stylesheets used.
Various modes can be toggled independently on each individual docked window. Just replace F4 with F3, and press the shortcut with the mouse over the intended docked window.
ALT+F2/F3 can be used to increase/decrease docked window size in overlay mode.
Comparing to normal main window docking, currently the overlay mode does not support side-by-side windows on the same docking area.Multiple windows in the same docking area will be grouped under a TabWidget, and switched using tabs.
Edit: new title bar buttons for convenience. Also introduce the 'Auto hide on edit' mode, which hides the docked window when editing object.
Now my favorite UI setup with Dark theme. How about we call it, "The Seamless".
Re: New overlay mode (soon ready for testing)
Wow, there are so many users looking forward this to be implemented! I think it would be a major step forward in perceiving FreeCAD much more professional.
Just a 2 consideration (to your already excellent implementation) since you are working on panels:
- it would be nice if the user could decide what to put into the combo view. For example: Tree and Task, or Task and Properties, or as it is now by default Tree, Task and Properties, or even Tree and Properties.
- it would be nice, but this is just my opinion, to have the structure toolbar also inside the TreeView, since it's commands are - to me - really related to what happens in the tree (i recall you probably do not agree with this, is it?).
- HakanSeven12
Nice
Support me: Hakan Seven on Patreon
Modern UI: Modern UI on FreeCAD Forum
Trails Workbench: Trails Workbench on FreeCAD Forum
It is already possible to do this with upstream. The setting is in Preferences -> Tree view mode. But with the current upstream, you need to manually restart FreeCAD, and manually toggle the visibility of the Tree/Property view. I have changed this to be dynamically applicable.
I don't quite understand this. You want the structure toolbar (the commands for making Part/Group/Link) to appear as tree view menu actions?- it would be nice, but this is just my opinion, to have the structure toolbar also inside the TreeView, since it's commands are - to me - really related to what happens in the tree (i recall you probably do not agree with this, is it?).
it is cool.
It looks like FC UI is moving slowly to a embedded style like sculptris
::bitacovir::
My personal web site
My GitHub repository
Mini Airflow Tunnel Project
my bad! I didn't know about that, sorry
I meant something like this:
This happens in a lot of drawing programs with the layer panel (gimp, krita ecc.).
The goal I have in mind is to have the cross-workbench commands integrated into the UI as much as possible.
- adrianinsaval
Would this be through an add-on or it has to be merged in FreeCAD? If it has to be merged, will it allow the old behavior? Nice feature btw! You never cease to give pleasant surprises
Still not sure what do you mean. Maybe a screenshot of those drawing program (I use gimp) and highlight the UI?
It's a core feature, and has to be merged. Maybe too late for 0.19 now. You can use F4 to easily toggle between overlay and old behavior.adrianinsaval wrote: ↑Fri Apr 17, 2020 6:55 pm Would this be through an add-on or it has to be merged in FreeCAD? If it has to be merged, will it allow the old behavior? Nice feature btw! You never cease to give pleasant surprises
Sorry, I was too hasty probably. I'll try to explain better what i meant.
The UI in FC is divided into a persistent part and a workbench related part.
The persistent part is made of panels (Report Tree Property Selection Combo PyConsole) and toolbars (File Workbench Macro View Structure).
Panels position is kept when you change workbench. Toolbar position is not (for example if in a workbench you change the Structure toolbar position, it will be of course changed just in that wb, so if you are not tidy - and i'm not - you end up searching for this toolbar when you change workbench because you will have it sometimes here and sometimes there).
This inspired the idea to have the persistent part of the UI more "fixed".
So for example, since I find the Structure toolbar related to the TreeView directly (Group and Part objects, when created, are visible just in the TreeView) I thought it would be nice to have it located inside the TreeView. Even if I know that the Document Tree is something very different from Layer panels from other software, It could be friendly if it behaves in a similar way. I'm attaching here some screenshot comparing Krita Gimp, Inkscape, Blender, where you find a red rectangle around the position of the creators of layers and groups:
So for FreeCAD it could be like this:
I find this place also interesting for the view options related to the TreeView: SyncSelection | SingleDocument, MultiDocument, Collapse/Expand |
Similar thing happens in many softwares for the 3dView: view related toolbar is overlayed over the view. (But here we are already up to date thanks to the NaviCube)
I am not in favor of this, FreeCAD is used by many users in very different ways, some may use the Part-Assembly structure for their model, some may not. Current gui layout with workbenches and toolbars could be improved in some ways but in general it actually very well support this different workflows. It would also be much better if users would start to learn and understand a bit more the parametric programs like solidworks, catia, inventor, nx, creo,... that are closer to freecad then pushing it in directions that have very little to do with it.
