I see. So realthunder did not submit a PR (pull request)!?
PieMenu (v2.0)
Re: PieMenu (v2.0)
Hi everyone,
I am on realthunder branch.
I have an issue with PIE menu.
I am on macos Catalina 10,15,7
I create a custom toolbar which I want to call by pressing a key. When I assign a letter, I can call the customized toolbar.
When I assign one of the F keys (F16,F17...) I have nothing. The customized toolbar does not appear.
The tab key can call pie menu.
Thanks for your help
Re: PieMenu (v2.0)
I can't find information about it now but I think only F1-F12 is supported in keyboard shortcuts.lebearnais wrote: ↑Sun May 08, 2022 10:20 am When I assign one of the F keys (F16,F17...) I have nothing. The customized toolbar does not appear.
Re: PieMenu (v2.0)
I try à lot of Fx. ( F2, F5,F12,F16…) but no success. Only key such as r are working
Re: PieMenu (v2.0)
And how about your setting in System Preferences->Keyboard->Use F1, F2 etc. as function keyslebearnais wrote: ↑Sun May 08, 2022 3:00 pm I try à lot of Fx. ( F2, F5,F12,F16…) but no success. Only key such as r are working
- adrianinsaval
Re: PieMenu (v2.0)
why use pie menu on realthunder fork when it has its own built-in pie menu
Re: PieMenu (v2.0)
do you have a site to explain the internal function of PIE menu in realthunder?
Thanks
Thanks
Re: PieMenu (v2.0)
I test both option: selecter and not selected. Same effectadrianinsaval wrote: ↑Sun May 08, 2022 5:19 pm why use pie menu on realthunder fork when it has its own built-in pie menu
Re: PieMenu (v2.0)
It is in Tools - > Customize -> Toolbars. The settings for it are in Edit -> Preferences -> Display (UI tab)lebearnais wrote: ↑Sun May 08, 2022 5:50 pm do you have a site to explain the internal function of PIE menu in realthunder?
Thanks
Uncheck the first checkbox if you don't want your custom toolbars eat all screen space.
- rt_pie_menu_settings.JPG (22.58 KiB) Viewed 1906 times
- rt_pie_menu.JPG (18.41 KiB) Viewed 1906 times
- adrianinsaval
Re: PieMenu (v2.0)
I think this should be rather discussed here: https://forum.freecadweb.org/viewtopic. ... hilit=menu or in a new thread in linkbranch subforum, this thread is for the external addon called pie menu which is very different. Can a mod please split the topic?
